Re: Wiring issue, grounding problem?
The dimmer switch contacts get dirty so I'd suggest you cycle the switch 10-20 times.
Gas gauge, check if the wire is connected at the tank, check voltage. The sender could be bad. Make sure the cluster pcb is grounded where it should be. |
