![]() Join Date: Apr 2006
Anyone running only tubular uppers? Bagging a '66
Curious if this will help the camber problem or create other new problems if i used stock lowers off of a 73-87 and only upgrade to tubular uppers?
Will be running airbags. Thanks in advance! |
![]() Join Date: Jan 2011
Re: Anyone running only tubular uppers? Bagging a '66
The tubular uppers are the same geometry so not much of a change from stock.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
So are you saying you get most of the geometry change from tubular lowers?
QUOTE=PGSigns;8245692]The tubular uppers are the same geometry so not much of a change from stock. Jimmy[/QUOTE] Posted via Mobile Device |
![]() Join Date: Aug 2014
I just changed my uppers to tubular when I lowered my C10. I wasnt able to get the alignment how I wanted it until I did change them and helped get my caster where I wanted it. Idk about lowers, everyone just told me to change my uppers. It was a 1965 chevy c10
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
So how do you like the setup running the stock lowers and aftermarket tubular uppers? Are you bags?
No Im static. My truck drives really well though for being as low as it is. It for sure helped with my alignment also.
So you only did the uppers?
I have a 68 that is lowered 3.5 in the front between drop spindle and spring height. It drives fine, but the 15" wheels did hit the lower stock arm and carved up my wheel weight. :/ |
Yes I just changed my uppers.
