Smoothie wheel for disc brake
I'm looking at summit racing US Wheel steel 15x8 series 51 smoothie wheel. I called us wheel and they said no, won't work with my 1960 with disc brakes. They gave me measurement of 7.5" from beed to center. I called CPP they said Measure top of caliper to center of dust cap. I seem to get 6-3/4". CPP also says to ask if they'll got 71 C10. I call US Wheel back and they say yes 71 C10 with drum, my understanding is 71 was all disc, maybe not, so I ask again and he says if stock 71 C10 they'll work. I call summit, they get some info and say they should work on 71 c10 with disc.
Anyone know? |
Re: Smoothie wheel for disc brake
That's a tough call on that one. Too bad you can't get your hands on a wheel to throw it on there and see for sure. I know the Wheel Vintiques 12 Series will fit over a standard disk brake swap, and those wheels are similar to those US wheels. If I were you, I'd remeasure with the ruler at the center of the caliper. From that angle, it looks like where you are measuring may be shorter than if you measure at the center.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#3 | |
I also measured at about every point along caliper and seemed to have 7" @ furthest point. |
That's going to be a tight fit! On my old Malibu, I had 12" rotors and Wilwood calipers behind stock 15" rallye wheels. I had to file the calipers down some to get them to fit behind the wheels, but I was committed to those wheels and wanted them to work. That's always a possibility for you as well if it's really close to fitting and you're willing to make it work.
A buddy of mine did a disk brake upgrade on mine with a kit using 90's Chevy truck 6-lug calipers. I have these wheels. I couldn't tell you if they are US Wheel or Wheel Vintiques (see photo attachments) but I had no issues clearing the discs & calipers.
Tony J ![]() |
![]() Join Date: Jan 2011
I am running the wheel vintiques 12 series 15X7 on the front and no issues. Running 2 1/2" drop spindles. I went with the narrower wheel to gain room on the lower control arm.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
