What transfer case do I have?
Can someone tell me how to identify my transfer case?
203, 205, 208... I know the differences between them but how can you tell them apart visually? Posted via Mobile Device
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift |
Re: What transfer case do I have?
The cases should have a tag on them. The 203 and 205 have a cast iron case and the 208 is aluminum.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
78K & 79C Jimmys
88 208
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Slots go on anything!
The easiest way (to me) is the shift pattern, and case construction. Your truck most likely would have a 208 case. The shift pattern from top is 2hi, 4hi, N, 4 low. The shifter is mounted to the cab floor, instead of to the case itself.
1974 Jimmy- 5.3/4L80e/NP241 |
pic#1 NP203
pic#2 NP205
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
Thanks guys... great info
What transfer case would come stock in my 1972 Chevrolet 1500 sb350
Should be a NP205
found this recently while browsing the interwebs..
TRANSFER CASE SPOTTER’S GUIDE posting pictures of yours will help too, good luck!
I started out with nothing - and I still have most of it |
Np 205 is that the one with the chain but more importantly where can I find a how to manual to dropping the tranny and transfer case down safety
np205 = part time gear to gear
np203 = full time gear to gear range box and chain for the front output .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
