Old 05-01-2018, 10:56 PM   #1
Desert_Eagle02
Assembly Line Photos
I stumbled across these on Facebook, thought you guys might enjoy seeing them. They said they are from Oshawa Ontario Canada.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 05-02-2018, 07:55 AM   #2
mingoman
Re: Assembly Line Photos
Those are awesome! Thanks!
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 05-02-2018, 11:04 AM   #3
Keith Seymore
Keith Seymore's Avatar
Nice. I've not seen those photos before.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-02-2018, 11:20 AM   #4
Mattchu60
Thats cool - the whole front clip went on as a unit it appears - Amazing that no paint ever got scratched up - guys must have been really careful.
Mattchu60 is offline   Reply With Quote
Old 05-02-2018, 12:36 PM   #5
Keith Seymore
It varied based on whatever is was en vogue at the time.
When I started in Flint, Line 1 pickups were built piecemeal (radiator support set loosely on the chassis, then LH fender, then RH fender, then hood) but Line 2 Blazer/Suburban was "buck build" as shown here. Same product, under the same roof; different process.
There were 7 full size truck plants building C/K pickups. The majority were "piecemeal" installations.
I dunno about that I will say, though, you want your best guys working that job.
K
1979-1986
1986 - 2019
Old 05-02-2018, 12:41 PM   #6
Keith Seymore
Note that in the motor set photo the driveshaft is already installed to the rear axle.
The front of the shaft is held up with a rubber bungie cord; the yoke is slid up into the trans as the motor mounts are settled down into the frame.
The brake master cylinder is held in its final position (more or less) via a temporary slave bracket, and the brake system has already been evacuated, filled, tested and verified to be good by this point in the process.
K
1979-1986
1986 - 2019
Old 05-02-2018, 01:31 PM   #7
Mattchu60
Keith, what would happen if for some reason paint were to be damaged with a panel install? Would the truck be pulled after assembly and it repaired, or have a panel replaced? or if its small enough would it simply just get a little touch up paint? I would imagine you don't want to be the guy that dings a panel.
Old 05-02-2018, 01:52 PM   #8
Keith Seymore
Exactly.
If it was just a little chip they would touch it up with a brush just like you or I would, before it was driven off the end of the line. Bigger repairs would go to a stationary paint repair area where it would be bumped and sprayed, then placed on a short moving line to go through a bake oven.
Major damage would get replacement panels. If the damage is extensive, particularly early in the build process (like the cab shop) sometimes it is easier to just scrap the vehicle and start over.
My '74 Chevelle, built in Oshawa, of which I am the original owner, must have gotten hit and repaired in the plant. When I stripped the front clip down the first time for a repaint I found bondo in the wheel opening area on one fender.
K
1979-1986
1986 - 2019
Old 05-02-2018, 01:55 PM   #9
Keith Seymore
My first "real" job was as the production line supervisor, Flint Line 1, Fender Set area, second shift. I had 27 production operators, 3 repair men, six or seven absentee replacement workers and one "quality man" (my right hand man).
My guys put on roughly 900,000 front clips (or 1.8 million fenders) over about a six year period.
One completed vehicle off the end of the line every minute.
K
1979-1986
1986 - 2019
Old 05-02-2018, 08:29 PM   #10
Wwes
What was the work schedule like, breaks, bathroom breaks, lunch, etc?
Seems like a lot of moving pieces to be choreographed just perfectly.
What happened if the vehicle wouldn't start? Did they prefill the carb bowls with gasoline?
Wwes is offline   Reply With Quote
Old 05-02-2018, 11:25 PM   #11
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
These are great pictures. Makes me think a bit about restoration. Some things would better to do like the factory did. Makes sense to do the front and rear suspension work without the front clip and bed installed. Same with engine work for the front clip.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 05-02-2018, 11:58 PM   #12
SKT
SKT's Avatar
Wow, too cool!!
Any more of these pics?
SKT is offline   Reply With Quote
Old 05-03-2018, 07:55 AM   #13
77 ChevySport
Wonder if there are any pictures out there that show how the Chevy Sport Stripes where put on?? This would be a picture to see! Larry
Attn.: Keith-Did you ever see this done when you worked there??
77 ChevySport is offline   Reply With Quote
Old 05-03-2018, 07:58 AM   #14
Keith Seymore
Originally Posted by SKT View Post
Wow, too cool!!
These are from my alma mater: Chevrolet Flint Assembly -
http://www.73-87.com/7387info/Assembly%20Line.htm
Scroll down for insightful commentary.
K
1979-1986
1986 - 2019
Old 05-03-2018, 07:59 AM   #15
Keith Seymore
No - ‘fraid not. That was before my time (or I don't recall).
K
1979-1986
1986 - 2019
Old 05-03-2018, 08:21 AM   #16
Keith Seymore
First shift started at 6am and ended at 2:30pm.*
The UAW was allowed a 6 minute break (paid) for every hour worked. Line 1 lunch was at 10:12 am (4.2 hours into the day) so the morning break was 25 minutes long. Lunch was ½ hour (unpaid). Afternoon break was at 1 pm and was 23 minutes. Line 2 lunch was at 10:54 am and the breaks were built around that. Second shift started at 4:30 pm, which allows time for the parking lot to clear between shifts. Typically third shift is for maintenance; there is not a third production shift unless you are building a really hot product.
Usually there was overtime, to make up for lost units (due to downtime) or to work repair. Final line might go "8.2" (eight hours and twelve minutes), with chassis, body and paint shops and other feeder lines going 9 hours to fill the system back up, including the various accumulators and body banks. Often after the line went down we would solicit volunteers to go "out back" and shuttle vehicles between the repair areas to work the backlog in the yard down. Overtime pays "time and a half", that is 1.5 times your normal rate with "double time" (double your normal rate) on Sundays or holidays.
Line 1 rate was 60 jobs/hour - that's one complete vehicle off the line every minute. Line 2 rate was 36 jobs/hour, partly because of the added complexity/content of building an SUV, partly due to market demand. Model mix on Line 2 was two Suburbans followed by one Blazer. Approximately every ninth vehicle was a GMC with the other eight being Chevrolet nameplated vehicles. Typical line rates in other plants fell somewhere between these two, with 45 an hour being a favorite for the van plants.
Lunch was unpaid, as I mentioned, but I had the discretion to pay the ½ hour as overtime if I deemed it necessary. I could pay a repairman to work the line back if we had just had a series of mistakes, or could pay my quality man to clean something up or do something out of the ordinary. I had some guys that I couldn’t get to work more than three days a week, and I had some guys that would kill a man on my behalf if I paid them that half hour overtime through lunch. It was essentially "free money" since it was 1.5 times their normal rate without adding any length to their work day.
There were two ways to do the break: “mass relief”, meaning the line shuts down and everybody goes at the same time, or “tag relief”, in which there is a team of workers trained to do every job where (“tag” – you’re it) they tap you and you go on break by yourself. When you get back they move to the next person. Naturally, there are pros and cons to each but it is primarily dicated by support staffs like the cafeteria, or number of available rest rooms, etc - or - if they need to keep that line running to support market demand. You can imagine the load on the cafeteria, water fountains, vending machines and bath rooms when 3000 people are all set free at once.
If you really have to go right now then either one of the relief men or the quality man can give you a quick break. If you really really need to go right now then I could cover for a couple jobs. I could do every job in my department, sometimes two at once, and many of the line workers could do their buddy’s job and cover for them. There is a pretty rigid social structure "in the shop" and the guys police this themselves, so you do not want to abuse this relationship.
The choreography is not too big a deal, since everything is locked together and starts and stops at the same time, like teeth on a gear. Just don’t jump a tooth – that’s a problem. Building the first few vehicles at the beginning of the model year, filling the system - that's hard. The next million or so are not so hard, provided everything stays in order.
Vehicles that don’t start (“deadheads”) were pushed off to a stationary repair stall just past the end of the line. We had two small tractors (tugs, which we called “mules”) which had rubber mounted to the front so you could push the vehicles off without damage and typically without shutting the line down. Vehicles were filled with 3 gallons of gasoline, and I don’t recall that they were primed first; just crank and crank until they fire. Once we went to fuel injection in 1987 then that was a non issue. Three gallons was deemed sufficient to get the vehicle through repair, shipping and to the dealership. We did have a few vehicles that needed so much shuttling between repair stations that we ran them out of gas.
K
*I'd like to have a little chat with whomever thought that was a good idea. Admittedly it was nice to be done by early afternoon, especially in the summer, but 6am comes really early, especially in the winter.
1979-1986
1986 - 2019
Old 05-03-2018, 08:32 AM   #17
Greenlee
Greenlee's Avatar
Keith,
I always enjoy the behind the scenes information you provide. It sounds like kind of a fun place to work, but I guess it might have sucked if you had to do it every day.
Greenlee is offline   Reply With Quote
Old 05-03-2018, 08:48 AM   #18
Keith Seymore
Originally Posted by Greenlee View Post
Keith,
Thank you; GM has a way of taking the "fun" out of "fun stuff".
You have to find a way that works for you in order to keep it fresh. For me, it's all about the product.
Note that I can remember what time we ate lunch 40 years ago, but I can't remember to stop and eat lunch during most days today.
K
1979-1986
1986 - 2019
Old 05-03-2018, 11:57 AM   #19
crossy
Oh,you can't buy that new
crossy's Avatar
And no one else is curious aboat (Canada, Eh!) the 400 emblem in the grille. Wonder if it was the 400(402) Big block or the 400 small block, NEITHER of which I have ever seen factory installed in a square body- NOT SAYING they didn't, But-------- thanks for the pics, Crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 05-03-2018, 01:06 PM   #20
Mattchu60
I thought the 400 small block was the big motor in the 70's pickups?
Old 05-03-2018, 01:12 PM   #21
Keith Seymore
Yah - it was available in the 4wd -
400 cu in small block
https://www.gmheritagecenter.com/gm-...tion-kits.html
(1978 info packet attached)
1979-1986
1986 - 2019
Old 05-03-2018, 01:17 PM   #22
Goats86
Small block 400 was very common in North Texas around 76-78. I twisted wrenches for a local Chevy dealership then.
Goats86 is offline   Reply With Quote
Old 05-03-2018, 02:14 PM   #23
gmachinz
Keith-do you have any knowledge regarding the CUCV military K20s? I’d be curious to know prior to the line, where did the assembly of the frame/suspension/brakes take place? And how about the exterior trim moldings, tailgate bands, etc? Have you ever thought about writing a book or a series of books on restoring these trucks using your knowledge and contacts?
gmachinz is offline   Reply With Quote
Old 05-03-2018, 03:06 PM   #24
Keith Seymore
Yes - we built the CUCV's in Flint, down the same line as the regular products. Every 12th vehicle was a CUCV when we were building those.
They were a little tricky (naturally) due to the added content. I had a diminutive lady that installed the batteries on the LH side of the line. She was supposed to do the battery in the CUCV but couldn't reach. After a while she wouldn't even try; My left side repair man (or me) ended up installing every one of those batteries until she could be moved to a different job more consistent with her strengths and limitations.
Also - the camo paint jobs on those - are standardized. They had the pattern hanging in the paint booth as a reference while spraying the various colors (green, tan) freehand.
Axle trim took place back in the axle bay, just like the commercial products. Front and rear axles were received at the rear of the plant (complete from hub to hub) and hung on a conveyor, in sequence. Axles were trimmed out by adding brake lines, shocks and selecting the appropriate drive shaft (per the build manifest) and hanging them on the same carrier.
We had a library of "wrong" tires on hand at the tire installation point. That way if axles got out of sequence, or a wrong axle installed, the corresponding wrong tire/wheel could be installed to keep the line running and the vehicle would be repaired out back.
Same with the frames. Frames were built up in the plant by adding the frame rails to a "pedestal line", which moved the material but also functioned as an assembly squaring fixture. Crossmembers were built up and added to these rails on the pedestal, along with body mount brackets, spring brackets and any other components that got riveted to the rail. After the frames were viable they were suspended by chains, upside down, until the springs and axles were secured. At that point they were flipped right side up to continue the rest of the process. The CUCV frames were fed into this flow just like everything else.
Prior to 1981 the mechanically attached trim (including the tailgate band) was added in the various trim shops (front end sheetmetal subassembly build, and cab/box trim on the main trim line). In 1981, when the adhesive side trim was introduced, it was installed on the final line using aluminum fixtures in an attempt to get it all on straight. It took a little while to dial in the right process of alcohol wipe, heat and pressure in order to get the moldings to stay on. For a while there you could see those adhesive moldings stuck along the roadway and on the guard rails up and down I-75 and I-69.
I've been told multiple times I should write a book but always related to the funny stories and anecdotes. A restoration guide is a little different nuance than has been mentioned before.
K
1979-1986
1986 - 2019
Old 05-03-2018, 03:52 PM   #25
Ski-me
Ski-me's Avatar
Thanks Keith....very cool.
I don't know a ton about the CUCV's but were they outfitted with 3/4 ton running gear? Specifically the Blazer? Compared to the standardly equipped 1/2 ton running gear?
Frame strength the same?
I believe they were 24V (where second battery was noted above).
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
