Old 05-29-2002, 01:40 PM   #1
1ToBjimmyk5
Talking 3/4 ton springs on k5?
can you just change to springs without any cutting/welding
How about helper springs?
coil spring shocks?
1971 Chevy Blazer(looks like Jimmy),1988 Ford E350 Van,2001 Nissan Sentra(Wife), 1993 Nissan Sentra (to/from work),1985 Dixie (boat) with a big Johnson,And I want my 1970 Buick Conv. back!!!!
Centreville,VA
1ToBjimmyk5 is offline   Reply With Quote
Old 05-29-2002, 04:15 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
the fronts should be the same, but i dont know about the rears......
remember a K5 is alot shorter wheelbase so a stiffer spring will make it ride ALOT worse, than a 3/4 truck with 3/4 springs
68SWB4x4 is offline   Reply With Quote
Old 05-29-2002, 04:24 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
blazer springs are most likely lots shorter in overall length
Fast68Chevy is offline   Reply With Quote
Old 05-30-2002, 11:24 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Thumbs up
I'd ask over on ColoradoK5.com. There are a lot of guys over there with 3/4 ton suspension on their K5's.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-30-2002, 12:06 PM   #5
Mike C
Mike C's Avatar
They will work if they are 52" eye-to-eye, not if they are 56". I have a set of National 3/4 ton 4" lift springs on the Jimmy. It rides rough, but it IS a 4x4 with 35" tires and a 104" wb, so I don't expect Cadillac style. They have not sagged a lick in the 12+ years they have been on the truck. Pulls my boat with a 400# tongue weight great.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-30-2002, 01:09 PM   #6
Fast68Chevy
Re: 3/4 ton springs on k5?
[i]Originally posted by 1ToBjimmyk5:
can you just change to springs without any cutting/welding?
coil spring shocks?
wish question was bit more specific, he could mean something else.. he is asling abotu swpping to 3/4 ton springs, but have to assume he means swapping from blazer leaves to 3/4 ton leaves on a blazer., if they are the same or not. no point in swapping to, he could just add some leaves, and cut length of each leaf he adds to the right length, 1/2 ton leaves would work fine, should be same width anyways, just add some more if he wants ot stiffen it more or lift truck a little bit more, but will need longer U bolts.,
