Old 05-05-2018, 12:11 PM   #1
pdr510
Junior Member
pdr510's Avatar
Old Air Cooling Fans on a big block?
Is anyone running the Old Air Products dual electric fans on an big block? Curious to see if they will fit with out clearance issues. I am running short water pump and on 72 big block mounts in stock location.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
pdr510 is offline   Reply With Quote
Old 05-05-2018, 04:06 PM   #2
weq92f
weq92f's Avatar
Re: Old Air Cooling Fans on a big block?
I considered it with my BBC, long pump, 4 core setup but just couldn't get past the price. My measurements showed it would fit without issue as the center is pretty thin compared to the center of each fan. The thing is pretty thick though. Also, just about all the reviews I read mentioned the noise it puts out so I went another route.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-05-2018, 04:27 PM   #3
pdr510
Junior Member
pdr510's Avatar
Hth,
-klb
Yeah, I have read about the noise they make, but I’m ok as long as it cools well. I wasn’t sure how much clearance is needed.
Old 05-06-2018, 12:07 AM   #4
Mollzyie
Mollzyie's Avatar
Hth,
-klb
Care to share what route that was ? Enquiring minds wanna know
I like to get new cooling fans . Not sure what I should go w .
M.A.G.A.
Mollzyie is offline   Reply With Quote
Old 05-06-2018, 09:28 AM   #5
72Cheyenne454
72Cheyenne454's Avatar
Member wshattuck used the Old Air dual fan set up on his ZZ502 build, I remember asking for the details because the fans looked really clean.
Try this link - post #41 has the link of the fans he used.
Miles
http://67-72chevytrucks.com/vboard/s...ght=502&page=2
72Cheyenne454 is offline   Reply With Quote
Old 05-06-2018, 12:49 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Old Air Cooling Fans on a big block?
Basic info. This off the flex lite site.
To choose your electric fan, we recommend that you determine the minimum airflow you'll need, because you'll want to rule out fans that won't cool your vehicle. Consider the following minimum cubic feet per minute (CFM) ratings for basic engines:
1,250 CFM for a 4-cylinder
2,000 CFM for a 6-cylinder
2,500 CFM for a 8-cylinder
A further note is that engines that are 5.0-liter (302 cubic inches) or larger should use an electric fan with 2,800 or more CFM. Obviously, an 800-horsepower engine will need more cooling than a 400-horsepower version regardless of the cylinder-count, but this basic guidance will get you started.
https://www.flex-a-lite.com/blog/how...-electric-fan/
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-06-2018, 03:22 PM   #7
weq92f
weq92f's Avatar
Went with the Champion 3-row w/ dual 14-inch fans and purchased a harness from local board member.
-klb
Old 05-06-2018, 06:56 PM   #8
Mollzyie
Mollzyie's Avatar
-klb
Thanks for the info Andy .
- very nice weq. Are u happy w your set up ? I have same radiator just haven't installed it yet . I'm willing to spend a lot on some good fans . Maybe I dont have to , but this cooling issue is killing me . I'm gonna also address the timing as well . Just gotta buckle down and do some research . Thank you .
M.A.G.A.
Old 05-06-2018, 09:01 PM   #9
Raleighswb
I used them for a few years,worked very well with my stock 402.No clearance problems,and yes they are a little noisy. The temperature gauge never got past 180 even on the hottest summer days.
Raleighswb is offline   Reply With Quote
Old 05-06-2018, 09:25 PM   #10
Andy4639
Old member
Andy4639's Avatar
Look into the Trarus 2fspeed an and Mark3 fans. They are some of the powerfulest fans out there.
I have the Tarus fan in my 64 SS Impala 350 and it never gets over 190* with the low speed. I have the high speed set on the AC.
The fan on high speed is like 3200CFM!
Old 05-07-2018, 10:16 AM   #11
Mollzyie
Mollzyie's Avatar
Yessss Andy . That's what I'm looking for man ! I'm looking for overkill 👍🏼 Thank you 👍🏼
M.A.G.A.
Old 05-07-2018, 10:29 AM   #12
davepl
davepl's Avatar
If you're doing dual fans, consider a triple-relay setup. If you can control the fan in two stages, it allows you to run:
- One fan on LO
- One fan on HI
- Two fans on LO
- Two fans on HI
It is the "Two fans on LO" where the fans get run in parallel at lower speed that is the key. It's much, much quieter that way.
This only works if you have two set points though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-07-2018, 12:13 PM   #13
Mollzyie
Mollzyie's Avatar
That's a great idea dave ! Thanks 👍🏼
M.A.G.A.
Old 05-07-2018, 12:29 PM   #14
weq92f
weq92f's Avatar
- One fan on LO
- One fan on HI
- Two fans on LO
- Two fans on HI
That's right, and I believe the harness you get with the Old Air fan set isn't this type of setup.
-klb
