05-01-2018, 08:41 PM | #6701 |
Re: What did you do to your truck today? Chapter II
Finally made the time to get the truck aligned.
Been gonna do it so many times but got distracted. Last year I replaced the tie rods and ball joints (both of which were the factory installed persuasion), and used the "String Method" to get it close. The guy said it was 1/4 inch off on one side (not too shabby), and a little out of camber on that same side. The old truck drives like a brand spa kin new truck now |
05-01-2018, 09:34 PM | #6702 |
installed my vent windows.....wow!!! that was a chore
finished up the door panels. worked on my seat. i put a 10'' sub under the driver seat so it threw my seat off a bit. got my seat covers in a few days ago. looking forward to that when i get off thursday......yeeeyaaaaa
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
05-02-2018, 12:40 AM | #6703 |
I cleaned up her house. Finally so nice to work in an organized space.
05-02-2018, 08:44 PM | #6704 |
Also got steering wheel in...waiting on coupler to put in steering box...new u-joints, painted driveshaft...
05-02-2018, 10:17 PM | #6705 |
Nothing interesting to some, but I'm enjoying prepping my engine block for paint and gaskets. I never used a tap and die before this project, but I'm a believer now. I've hit all the female threads on the block etc.,. It's nice being able to screw a bolt all the way down with just your fingers.
Other than that I'm still waiting on a welder before I get the frame powder coated, and start the build. There's plenty to keep me busy until then. There will be a fresh block and transmission waiting for it when it arrives home. Man this takes up a lot of time
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-02-2018, 11:36 PM | #6706 | |
05-03-2018, 12:40 AM | #6707 |
That's a GREAT idea, thanks. I may brush POR15 on, but if I spray I'll use them. Heck, may use them regardless.
05-03-2018, 07:13 AM | #6708 |
Old member
Got some paint on the ramp truck tilt column.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-03-2018, 07:48 PM | #6709 |
I ran my front brake line mounting hardware under a wire wheel and cleaned them up. They look like they are original, and I am glad to have them. Could they be stainless?
05-03-2018, 07:58 PM | #6710 |
Finally got my base model side markers. I know it wasn’t original but I went ahead and wired them up, can’t be too visible these days. Just used Scotchloks so no damage done. Put new dash vents in. And replaced the air control lever that broke.
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles. Build:Ole Blue Millennial and can drive stick. "Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern |
05-04-2018, 10:45 AM | #6711 |
seat bottom last night.....
and door panels a few days ago fixing to work on the seat back. waiting on my seat belts to bolt everything in
05-04-2018, 11:22 AM | #6712 |
friends don't let friends use scotchloks
I started out with nothing - and I still have most of it |
05-05-2018, 02:16 PM | #6713 |
Bodge Repairs
My Son who's also a Journeyman Mechanic likes to say 'where you find a scotchlock connector you'll find a problem ' .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
05-05-2018, 04:58 PM | #6714 |
Finished welding in the rocker and cab corner. Next is the new cab mounts, control arm bushings and core support bushings
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
05-05-2018, 05:35 PM | #6715 |
Re: Bodge Repairs
What, why? We’ve never had any issues with them. I dialecetric greased the contacts and sealed the ends with liquid electrical tape. Mine are inside the rubber boot on the tail light on the rear so they’re not going to get banged around. What would be your recommended solution without pulling the wiring harness out?
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles. Build:Ole Blue Millennial and can drive stick. "Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern Last edited by 1968 baby blue C10; 05-05-2018 at 06:14 PM. |
05-05-2018, 07:06 PM | #6716 |
Finally got the rubber floor mat from LMC, it’s pretty nice, hated having to cut the hole for the shifter, a little nerve racking cutting a brand new mat. Replaced the hood shock insulation, made a world of difference shutting the hood and hitting bumps. Replaced the dash vents. Replaced the air control lever that broke. Got rid of the plastic rear view mirror and put an old school looking chrome one on.
05-05-2018, 07:14 PM | #6717 |
Repaired a few dents in the roof. Absolutely love this tool! Must have if your doing body work.
Pushed the turn downs back a bit. Pointed them straight out as well. Sooo much better back from the cab. Gets rids of exhuast fumes and the drone of the mufflers. Also not kicking up dirt when driving down a dirt road. |
05-05-2018, 07:19 PM | #6718 |
Those are awesome. Dad did bodywork for 20+ years and he always talked about how useful those were. He still uses his quite a bit.
05-05-2018, 07:47 PM | #6719 | |
Re: Bodge Repairs
greasing, taping, sealing, whatever defeats the intended purpose of a scotchlok as a quick connector, might as well install a proper connector and enjoy a good connection.. I'm tired so I'll let the interwebs answer the why questions.. The Problem with Wire-Tap Connectors as far as what you should do, stop making midspan harness intrusions and run your accessories to a reliable source like the fuse box or a junction box.. besides the conductor wire damage to original circuit and the insulation damage, the circuit is now possibly overloaded with the new circuit you introduced.. new circuits should have their own circuit breaker or fuse protection properly sized for the component rating and intended load.. let us know a specific wire run and we can assist you.. apologies for drab answer, but I'm pooped at the moment.. good luck!
05-05-2018, 10:14 PM | #6720 | |
Re: Bodge Repairs
The place Dad worked produced flatbeds on the side and installed them. He said the guys who wired them did every single light on them was with scotchloks. Which was a lot of lights. Why? I don’t know, but he said they always worked and never had any complaints. If the circuit was overloaded wouldn’t it blow the fuse that it’s wired to? And why not just solder the connection and then upgrade the fuse if so? Running a wire from the rear of a long bed to the fuse box for marker lights would be a pain.
05-06-2018, 12:16 AM | #6721 |
Scotchlocks are a prime place for corrosion to begin .
Even here in the Southern California Desert they cause all manner of dim and flickering lights . When I wanted a trailer plug for my '69 C10 I got a spare sub harness from the junkyard and worked it into the stock harness using the factory plugs . I have no idea how GM made their accessory trailer sub harness' but this is how most other manufacturers did it way back when . Saying 'that's too much work' means you're not the right one for the job . If your setup works, don't sweat it, just remember to look there first if ever any problems .
05-06-2018, 09:24 AM | #6722 | |
And that’s what I’ll do, if it’s not broke don’t fix it. But now I know to be wary of them in the future.
05-06-2018, 11:22 AM | #6723 |
And here I thought they were just my own pet peeve. Here in northwest Oregon I've never found one that the cheap piece of metal wasn't rusting away inside.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-06-2018, 07:31 PM | #6724 |
I brought her home.
Well, almost. 1st to the local garage for some cleaning, new fluids and going over. 15 years collecting dust in a garage to overcome. Soon it'll be sitting in my garage, and being polished, cleaned and pampered. Hopefully all 5 of the pictures are attached as planned. Mike
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car. 1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof. |
05-06-2018, 07:37 PM | #6725 | |
