Old 04-29-2018, 02:22 PM   #1
04ls1gto
Ls radiator options
Just wondering what everyone is running for radiator and fans with there ls setup? My setup is a L96 with a small cam and 6l90 trans in my 71 c10 suburban. I like the entropy setup but not the price. Looking for something a little more affordable
04ls1gto is offline   Reply With Quote
Old 04-29-2018, 09:46 PM   #2
racecougar
racecougar's Avatar
Re: Ls radiator options
BeCool radiator with a '94-97 Thunderbird/Cougar electric fan here.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 04-30-2018, 09:54 PM   #3
truckdude239
truckdude239's Avatar
I have a cold case radiotr and fans i got it when they had a fourm discount it has a life time warranty runs cool and fans move alot of air was around 450 with forum discount but i dont know if they still offer the discount
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 05-01-2018, 08:24 AM   #4
Steve Cole
If you like the entropy but not the price you can go with their import line, Engineered Cooling Products. They are about half the cost and still look good. They don't have a LS swap radiator with both hoses on the same side though. Here is what I am gonna use. I got about $620 in it but most of that is the fans. They move 4000 CFM though!
Steve Cole is offline   Reply With Quote
Old 05-02-2018, 10:06 AM   #5
twittersucks
twittersucks's Avatar
I don't understand the inlet and outlet on the same side for an "LS" swap radiator. They cost more than a standard radiator "by a lot" and serve no discernable purpose that a normal radiator doesn't/can't do. I say this because the 2008 Escalade that I got my motor/tranny out of had it's radiator inlet and outlet in the standard SB chevy orientation so this indicates to me that it's not necessary to buy the swap radiators. I can see it if you have an issue with clearance on one side but in these trucks that isn't an issue as far as I can tell. Just my 2cents.
twittersucks is offline   Reply With Quote
Old 05-02-2018, 01:55 PM   #6
verdell
verdell's Avatar
Cougar, I'm planning the exact same set up with my L33 swap next month. Are you satisfied with the Be Cool and the T-bird/Cougar fan? Is it the 2-speed fan?
verdell is offline   Reply With Quote
Old 05-02-2018, 03:41 PM   #7
mongocanfly
mongocanfly's Avatar
on my 81 swap I just stuck with the stock radiator....no issues...put dual fans on it from summit...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-03-2018, 06:54 AM   #8
homemade87
I agree with mongo . No need for an expensive radiator if you stock one is in good working order . I to use electric fans and made a homemade shroud to mount my fans on my 82 . I support over 500hp . If I had no radiator I would still use the stock one . I have maybe 150.00 in mine with the new ford fan and my time invested . Cools rock solid .
homemade87 is offline   Reply With Quote
Old 05-04-2018, 10:47 AM   #9
Willie Makeit
Willie Makeit's Avatar
same here. stock 4 row with two cheap Spal fans & a fabricated shroud. cooling a supercharged 5.3, a vintage air condenser and an air-to-fluid heat exchanger for the supercharger. truck never gets over 220.
Willie Makeit is offline   Reply With Quote
Old 05-06-2018, 01:40 PM   #10
67pete300
For those running Ford fans, are they available new from places like Rock Auto? Or only junkyards?
Any specific years and models?
67pete300 is offline   Reply With Quote
