Old 05-02-2018, 03:28 AM   #1
mongocanfly
mongocanfly's Avatar
LS mounts
I know ive seen a few people on here use either of these universal style mounts...
wondering about whether they have any vibration issues ,or are they about the same as the clamshell mounts?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-02-2018, 03:31 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: LS mounts
why would one use these over stock tower, stock mounts and an inexpensive adapter plate?
not knocking, honestly curious.
Willie Makeit is offline   Reply With Quote
Old 05-02-2018, 03:36 PM   #3
mongocanfly
Re: LS mounts
custom install...picture a bare frame with a engine sitting there that needs connected to each other...
what you suggested I've used in the past with good results. ....just looking for something simple....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-03-2018, 02:52 PM   #4
Willie Makeit
Re: LS mounts
i guess i still don't understand, you can take a bare frame / engine and connect it just as i described.
nothing simpler than bolting stock parts together
Old 05-03-2018, 05:57 PM   #5
binford
Re: LS mounts
watch this from summit racing
binford is offline   Reply With Quote
Old 05-03-2018, 06:50 PM   #6
tinydb84
tinydb84's Avatar
Re: LS mounts
I made a set of mounts using a bushing similar to that. I don't like them to be honest. They have way more play than the stock mounts did. When I put my engine back in, put the bolts in, and let the hoist down the engine continues to lower another half inch or so. Seems like too much for me.
David
Instagram: myfabguy
Old 05-03-2018, 06:55 PM   #7
mongocanfly
Re: LS mounts
ok willie....let me break it down for you...[sometimes I confuse myself]....this is a LS going in my IH build...the IH has a single front engine mount...there is no crossmember,towers ,mounts or anything else.....stock or otherwise...to just bolt right in...no side mounts or anything....its just 2 frame rails .....im going to have to fab a crossmember for the engine and if those style mounts I showed don't cause vibration issues im going to fab a set of those as well...to better clarify it heres a pic of the frame...yellow arrow pointing at front engine mount
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-03-2018, 07:06 PM   #8
mongocanfly
Re: LS mounts
thanks binford..that video kinda confirms what I suspected about poly bushings.. so I would go with rubber....
tiny..what bushing did you use..poly or rubber?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-03-2018, 08:31 PM   #9
binford
Re: LS mounts
I have a 73 scout
Correct you will need to buy or Fab mounts.
I like poly engine mounts with rubber trans / transfer mount.
Anything Scout has LS mounts on there website.
Which use leaf spring bushing.
I would buy some stock ls mounts from RockAuto and Fab a bracket from those.
I will have a used set hopefully in a couple weeks, as I'm putting my motor in my Chevy pickup.
At least I can post a picture. Plus I know what the scout mount looks like
Old 05-03-2018, 08:48 PM   #10
mongocanfly
Re: LS mounts
ive still got a set of LS mounts from my last swap....somewhere....I may just use those if I can find em....I saw those from anythingscout before....they look good...but a bit pricey
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-04-2018, 10:03 AM   #11
Willie Makeit
Re: LS mounts
gotcha. had you said IH frame from the beginning i would of bowed out, i was assuming we were talking chevy, being this is a chevy site and all.
Old 05-04-2018, 10:07 AM   #12
tinydb84
tinydb84's Avatar
Re: LS mounts
I used 4 inch long poly. Im thinking of machining an aluminum donut to put inside and limit the movement. Either that or make a new set of towers to use the old mounts. I have a 4 inch Z and need to bring the engine down.
David
Instagram: myfabguy
Old 05-04-2018, 02:12 PM   #13
mongocanfly
Re: LS mounts
yeah willie ...that's why I didn't mention what it was going in...I was trying to keep it a generic question about the mounts themselves....haha
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-04-2018, 02:58 PM   #14
tinydb84
tinydb84's Avatar
Re: LS mounts
Here are the pics of the mounts I made. I made the first set then was concerned about the lack of triangulation with the frame rail. I remade them but didn't account for the forward sump of the Fbody pan I was switching to.
David
Instagram: myfabguy
Old 05-04-2018, 06:55 PM   #15
mongocanfly
Re: LS mounts
those look good tiny!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-07-2018, 06:54 AM   #16
sluggy
Re: LS mounts
I used the ones on the right in your pic at the top. This is in a 62 that was using a horseshoe mount on the old 327. Done about 3500 miles on them, no problems so far !! Touch wood !! Not noisy at all, have checked them and the appear to be not breaking down at all.
sluggy is offline   Reply With Quote
Old 05-07-2018, 11:49 AM   #17
binford
Re: LS mounts
I like the DayStar poly bushing
There not as hard as most poly bushing.
These guys carry just the bushing or a complete unit.
They offer 15% off or free shipping around each holiday.
http://www.wfoconcepts.com/pr/YJ-Large-Bushing-Kit/3625
These are used for many things, one being motor mounts.
I would use them in my build, but going to try the stock mounts.
