Old 05-07-2018, 12:02 PM   #1
davepl
davepl's Avatar
Does anyone make a 3-relay fan controller?
I made one of these for my Camaro and it works great, but it's a lot of crimping and wiring and so on! I'm wondering if anyone makes one of these that I can buy off the shelf.
Basically its 3 relays so that you can set it up to run both fans in series on the low speed line (which is nice and quiet) and then in parallel when both wires go live.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-07-2018, 03:02 PM   #2
Steve Cole
Re: Does anyone make a 3-relay fan controller?
Hey Dave,
Derale makes a PWM controller that will turn the fans on a temperature that you select. I want to say the fans run at 60% initially (maybe less) and only increase as needed to cool to the set temp. I liked this because the fans put out 4000 CFM so I figured they would never run above 60% and be nice and quiet. Plus, they use soft start technology so they gradually spool up instead of 100% at once.
Steve Cole is offline   Reply With Quote
Old 05-07-2018, 03:11 PM   #3
weq92f
weq92f's Avatar
I purchased one from local board member. It's the type where first signal runs in series ( half power or 6 volts ) and the second trigger/signal runs at full power or 12 volts.
gmachinz
He builds them to order so it takes a while to receive but it's a quality harness. I can shoot pics if you like.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-07-2018, 03:12 PM   #4
MARKDTN
You might be able to do this with a Volvo relay. It is used to control a 2-speed fan. You could wire low speed to 1 fan and high speed to both (but you would have to add a big diode on the one that was used twice). Just Google "Volvo fan relay" and you can find wiring diagrams.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-07-2018, 10:55 PM   #5
davepl
davepl's Avatar
gmachinz
-klb
That's exactly what I want! If you have pics, please share!
Old 05-08-2018, 01:59 PM   #6
weq92f
weq92f's Avatar
His off the shelf harness includes a thermostat set for triggering the fans at certain temperatures. Since I have a PCM under the hood ( EFI computer ) that has two fan triggers, all I needed was the harness that included the triggers ( negative/ground triggers ).
All leads are labeled.
Hth,
-klb
Old 05-08-2018, 02:44 PM   #7
87Skier
87Skier's Avatar
The only issue with this is the volvo fans use two sets of coils in the fan (like windshield wipers) so they only take 12 volts to turn on. You would need another relay to switch the fans from series to parallel configuration.
I used the same wiring setup as the one posted above. I bought one of these fuse boxes https://www.waytekwire.com/products?pSearch=15303. It doesn't reduce the number of crimps you need to do, but it does make the installation a bit tidier.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 05-09-2018, 10:21 AM   #8
davepl
davepl's Avatar
Cool, I don't need the thermostats, just the ground-trigger lines.
Here's a pic of the last one I made, it's just a black box with two LEDs to indicate what power state the fans are in.
I also found this on Amazon, just looking at it now:
https://smile.amazon.com/Painless-30...30117+painless
Old 05-09-2018, 11:03 AM   #9
davepl
davepl's Avatar
I talked to Painless tech (which has an unlisted email!) and they confirmed that I can use the ECM to activate the two trigger lines. Just waiting now to ensure they run them in series/parallel rather than 1/2 fans.
Old 05-09-2018, 11:09 AM   #10
davepl
davepl's Avatar
Dang it, no luck:
"This will activate each fan individually according to the High and
Low commands coming from the ECM; see Figure 2. Both fans will activate when the A/C
compressor is activated."
