Old 05-01-2018, 05:46 AM   #1
Funstuie
vinyl flooring/carpet - sound deadening/heat sheild options?
hey all,
Another Q from me. Currently, my 76 has crappy, torn, disgusting carpet installed. I am going to rip it out and I was thinking of going with vinyl as it will be easier to clean and maintain. I will have to take out all the original bitumen as it's knackered and broken.
Having a look at options available most of the carpets have extra thick backing as an option but the vinyl doesn't. So what are you guys putting under the vinyl?
I am looking to keep it cheapish so I am thinking of peal and seal but is that enough? Should I look for an additional top layer?
Funstuie is offline   Reply With Quote
Old 05-01-2018, 07:21 AM   #2
70GMCer
70GMCer's Avatar
Re: vinyl flooring/carpet - sound deadening/heat sheild options?
On the cheap.... Frost King Duct insulation. It is aluminum with sticky back foam.
https://www.homedepot.com/p/E-O-12-i...V516/100028603
I've used this stuff for years and works pretty good.
It can be had for around $18 a roll & can be bought at Home Depot or Lowes.
70GMCer is offline   Reply With Quote
Old 05-01-2018, 11:02 AM   #3
RedBed
RedBed's Avatar
I've used something similar in my doors and it does work well and is much cheaper than "deadening material"
As far as vinyl, I got my flooring from www.73-87chevytrucks.com (CaptKaos - member) and it is VERY heavy duty and I am happy with it. Takes a little work to get it cut and in, but worth the time.
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 05-01-2018, 01:09 PM   #4
Tiger Joe
I've had really good luck with some knock off bran sound deadening from amazon. took a chance on it on the first truck 2 summers back, liked it so much we used it under the rubber floor in our 79 C30. definitely helps a lot
Tiger Joe is offline   Reply With Quote
Old 05-01-2018, 07:41 PM   #5
TKCR
TKCR's Avatar
When I did my interior, in first put FatMat down, even on the back wall. Then the original tar Mat. Next I put a foil backed insulation, from Home Depot. It comes in various sizes.
https://www.homedepot.com/p/UltraTou...1406/100656748
Lastly the carpet went down, which also had jute on the back.
The cardboard tool tray, I installed a thick speaker/amp carpet.
Old 05-02-2018, 07:58 AM   #6
mingoman
Man that looks great!
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 05-02-2018, 04:37 PM   #7
TKCR
TKCR's Avatar
You can check my build thread out and see the finished interior. The link is at the bottom, on my signature. It shows a few more pics on the process of the sound deadening.
Old 05-07-2018, 11:51 PM   #8
mikelom
Fatmat is less expensive. Just put 2 layers to make it more effective.
mikelom is offline   Reply With Quote
