Strange thing on my 78 crew
My 78 crew has this big receiver hitch and because of it it has 2wd spring hangers and blocks under the springs everything else checks out correct title is right and the front springs hangers are correct it's not a conversion has any ever seen this before and where can I get the correct rear spring hangers thanks guys
Posted via Mobile Device |
![]() Join Date: Jan 2003
Re: Strange thing on my 78 crew
Its hard to decipher your long sentence. Do you have pictures of what is going on?
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
#3 | |
You are still hard to understand.
I am going to assume you have a 4wd(you did't say how many wheel drive your truck is) If the spring hangers are riveted to the frame, they are original. If they are bolted to the frame, thay are not original. |
Yes it's 4wd and yes the are riveted I was just wondering if any one has ever seen this
Check the SPID in the glove box. In the 70's, if you were willing to wait rather then buy off the lot, you could really customize a truck. Could be that was a factory option to accommodate that hitch. Or it could have been a dealer special customization.
Is there something not working with the truck as it is? If it has been working 40 years as is, I would not be in a big hurry to spend money to 'fix' it. |
I am restoring the truck and I want to run a 4 inch lift but with this set up I'll have 8 inches in the back to make it right just trying to keep it factory looking other then the lift
Early k30s had the 2wd hangers. You need to pull hangers from a later k30 if you want the taller hangers.
If you're restoring it then keep the factory hangers. That's pretty unique to your truck. Put a 4 inch spring and then that block and it would still look like an original lifted.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
yep first year or so was 2wd front hangers for rear springs and 3" block with bump stop molded to it .
the 4wd hanger pattern for riviots is different than 2wd pattern . do a 4" flip kit and leave the block or swap hangers and ditch block . side note if you ditch the blocks send me a private message i will buy them . also early dana 60 fronts had a cast iron cap on the pass side king pin . the later units went tin cap .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
