Re: Question on engine brackets
My frame (steering box) is 72 and when I put in the 1990 serpentine system I took the fitting from the rear of my 72 pump and screwed it into the 90 pump because the hose end was different. The pump was nearly identical. Simple fix. If you desire to use the newer box for another reason then I have no experience with that. BTW your alternator wiring will have to be retrofitted due to the 88 being internal voltage regulator.
| Bookmarks |
