![]() Join Date: Mar 2011
67-68 brake lines pictures
So if someone would be able to posts some pictures of how the position of the original front brake lines were installed by the factory I promise to take great pictures to share when I’m done ....I have purchased the lines from Inline tube for 67-68 my dilemma is....I replaced the engine cradle on my 72 swb frame with a 67-68 my pictures and my other to trucks /examples are 71-72 ....really not that hard to figure out but a picture and proper position across the C-member and up to the master and down the frame to the rear would help
Thanks Jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Re: 67-68 brake lines pictures
top
![]() Join Date: Dec 1999
![]() ![]() ![]() ![]() ![]() I wish I had pictures from before I started. But, I nearly exactly duplicated the factory lines. My lines from the master cylinder down are not pictured because I didn't know what the factory ones looked like. This truck was a factory 1968 6 cyl manual brake truck. I converted to front disc and changed the booster from when a previous owner had a 3/4 ton booster and master cylinder installed. I notice in the pictures one of my lines has popped out of the crossmember clip. It snapped back in...but I'm not getting a new pic. |
thank you Jason , I may play with this tomorrow let you know how i make out
thanks again Jess
wow! that is a nice truck
![]() Join Date: Dec 2012
Looks great!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
