Old 05-17-2018, 02:31 PM   #1
hotwls13
Is my gas gauge working correctly??
I think it’s working, but thought it would read higher. My new to me 70 gmc lwb 1/2t 350/350 had a half done blazer rear tank swap when I got it. I think I have everything hooked up right etc. when I first got the truck when started I “think” I remember the gauge going way to the right. Found neither sender wire (ground or the brown wire) were hooked up. I hooked them up but only had like an inch of gas. At that point the gauge read a bit below E. Today I finall got time to get 5 gallons in it. Now it reads about 1/8?? Thought it would read more like 1/4 since I “think” it’s a 21 gallon tank.
Thoughts?
hotwls13 is offline   Reply With Quote
Old 05-17-2018, 08:42 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Is my gas gauge working correctly??
I think it looks good. You'll have more information when you do a fill up. I bought a nice clean new wooden dowel from the lumber store to dip in the tank and see how much gas I had and compared the reading on that to the gas gauge. I did that for a while through the whole range of full to empty. Just to get a feel for the situation.
Old 05-17-2018, 08:53 PM   #3
hotwls13
Yeah truck is still kinda torn apart. Bed is off. I’d rather know the gauge is working before putting the bed back on. I’ll probably have to lug another 5gallon gas can (or two) to verify it’s going up properly. I think I had read where the “new” metal floats were filling with gas (causing low readings) and guys were replacing them with Jeep floats.
Old 05-17-2018, 08:53 PM   #4
Smitty
Smitty's Avatar
Suggestion: Vent to both sides of the tank. The guy who installed mine just did the vent on the passenger side and it is a pain in the ___ to fill. Am having the vent hose added on the nipple on the drivers side as well. So it will vent faster when filling it up.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-17-2018, 09:08 PM   #5
dmjlambert
dmjlambert's Avatar
Are you all using roll over valves?
Old 05-17-2018, 09:48 PM   #6
hotwls13
I’m planning on only doing the drivers side. The large 1/2” vent line right next to filler on the tank. Planning to run that up into fender.
Old 05-17-2018, 10:38 PM   #7
hotwls13
I'm not sure which are vents and which are supply lines on mine. I believe at least one of the small ones is for fuel injected engines. So the lines may go to bottom of tank instead of just venting at the top. Pretty sure the big one next to fill is main vent though.
Old 05-17-2018, 10:56 PM   #8
Grumpy old man
Grumpy old man's Avatar
this thread should help
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
Old 05-18-2018, 11:21 AM   #9
demian5
demian5's Avatar
You could pop for a new sender, and make sure all the grounds are good and clean.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-18-2018, 01:24 PM   #10
hotwls13
Put another 4+ gallons in. It’s moving up so it’s working. Just not sure how accurate it is. I’d guess about 8 gallons in a 21 gallon tank.
Old 05-18-2018, 04:45 PM   #11
hotwls13
I grounded to the tank bolt that bolts tank to the frame. Looks like it’s moving so I’m guessing it is good. I’m gonna keep adding fuel as I can get to the gas station. Maybe have it full soon.
Old 05-18-2018, 06:32 PM   #12
demian5
demian5's Avatar
Good ground at the cab to frame and cluster to cab?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-18-2018, 06:36 PM   #13
hotwls13
No idea if those grounds are good or not. Wouldn’t a bad ground just cause it not to work at all?? It’s working, it’s going up when I add gas. I just wasn’t sure if it’s eyeball accurate.
I’m done troubleshooting it for now (too many other things to do). Once it’s full if it’s not reading full, I’ll get back to testing things.
Old 05-18-2018, 07:04 PM   #14
Grumpy old man
Ok , You know the gauge is moving when more fuel added raised the gauge level . just remove the tank pick up and straighten the float rod a bit to make the gauge move up ,you may have to adjust more than once to get it close , with a 21 gallon tank that you added 8 gallons to it should be just below 1/2 on the gauge. carry a small gas in back and drive the truck until it reads empty . the small can of gas is in case it runs out . don't chase electrical gremlins when a simple adjustment of the rod will do the trick !
Old 05-18-2018, 07:13 PM   #15
WorkinLonghorn
WorkinLonghorn's Avatar
Yep, that's the ticket right there ^. Listen to Grumpy.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
