Old 05-18-2018, 11:48 PM   #1
68 Donkey
need advise on my column shifter / 4L80e
I have a 68 C10 and my plans are to drop a LS3 with a 4L80e into it. I would really like to keep a column shifter. Do you know if there is linkage out there that will allow me to do that ?
68 Donkey is offline   Reply With Quote
Old 05-19-2018, 12:10 AM   #2
jessemthompson
Re: need advise on my column shifter / 4L80e
Lokar has a linkage setup and a cable setup that will work for you.
jessemthompson is offline   Reply With Quote
Old 05-19-2018, 03:04 PM   #3
68 Donkey
Thanks , I just looked it upon Lokar.com and that should do it
Old 05-20-2018, 12:40 AM   #4
2500HD
2500HD's Avatar
you will need the 26" piece. i do not recall the part number. the 21" (i think) will not work.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
