#16 |
![]() Join Date: Mar 2007
Re: Electric Fan Issues - space?
I had space issues with my 48 and originally went the route out a cheap pusher fan of Ebay. I soon learned I had cooling issues. I went with a Cooling Components puller fan. Here is their site:
http://coolingcomponentsinc.us.com One of their fans is 2 5/8" thick and comes with a housing you can trim to fit. They also offer a two speed switch and they move some CFM's. They are not cheap but very effective. After talking with them they also suggested not using the (convenient) flex radiator hoses. The corrugated surface of the hoses causes turbulence on the inside of the hoses which effects your coolant flow rate. Once I changed my hoses (I went with bend pipe for hoses) and my fan I no longer had any cooling issues. I should mention that I did notch the core support to push the radiator as far forward as I could to clear to gain every inch I could. Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
