Old 05-06-2018, 01:20 AM   #26
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: DIY Wood Gantry or 2 Ton Engine Hoist/Lift??
Originally Posted by hotwls13 View Post
That’s a shortbed isn’t it?? I don’t doubt my lift can handle the weight (even at the 1/2t length). It’s the length of the longbed that gives me concern. Due to the balance or lack of balance from being too far rearward.
Have you got a load-leveler bar?
Old 05-06-2018, 04:35 PM   #27
hotwls13
Nope
hotwls13 is offline   Reply With Quote
Old 05-07-2018, 01:51 PM   #28
hotwls13
Got the garden cart out using the new lift. On sawhorses at 4 corners now. Enough room to get the lift underneath when putting the bed back on. I'm thinking adjusting the supporting 2x4s in the H pattern I plan to use should get it balanced when lifting the whole bed??
Old 05-07-2018, 03:32 PM   #29
'68OrangeSunshine
Rock and Roll!
Old 05-08-2018, 11:21 PM   #30
hotwls13
So what else will work? I tried the 2x4 way in a H. It lifts the back but front not lifting. Would chains or straps of different lengths force it to rise front and back at the same time even though it’s unbalanced?? Boom and legs are about a foot too short to hit center.
Cant post pics right now cause of some token thing
Old 05-08-2018, 11:35 PM   #31
Knight72
I used my two ton to pull my long bed last week. Four solid ratchet straps and chain hook. No problems. Never felt too sketchy.
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
Old 05-08-2018, 11:44 PM   #32
hotwls13
From the rear like I am doing?? If so, your boom didn't reach center of bed correct?? what was your process? I have straps, did you drop the front two through the front stake pockets and then use the rear tailgate holes for the back two?
Old 05-08-2018, 11:54 PM   #33
Knight72
I positioned my boom as close to center as I could get from the tailgate end. Boom toward cab, Legs under differential. One long thick strap looped thru my hook and attached to the driver and passenger side stake holes. One strap thru my hook and left and right mid stake holes. Last two straps I hooked into the holes near the tailgate mounts on left and right. I cranked down the most on the ones hooked to the front stake holes due to the off balance. Mid and rears for support. Lifted and moved back and over to the side very carefully and sat it on the stand I built to hold it. It took about 15 minutes. The cab was another story. It went tits up pretty quick, grabbed a friendly neighbor and we lifted it off.
Build thread:
Old 05-09-2018, 12:12 AM   #34
hotwls13
OK Great, thanks for the details. That's what I had envisioned. Was your bed balanced when lifted or was the front lower?? I'm trying the strap idea tomorrow. I'm not quite ready to put the bed back on but really close. Want to be sure I have it figured out before attempting the real deal.
Old 05-09-2018, 12:15 AM   #35
Knight72
No problem. Mine was pretty level. Maybe a inch lower in the front. But not anything I was scared would be too unsafe. I cranked it just high enough to clear the frame and wheels.
Build thread:
Old 05-09-2018, 12:30 AM   #36
hotwls13
Another question, where on/in the stakepocket did u attach ratchet or hook ends? My stake pockets don’t really have much of a lip at the top. It would be best to run the whole strap through the entire stakepocket but the hole on the bottom of the fronts is pretty small. Or did u just hook to the bottom of the front stake hole?
Old 05-09-2018, 08:46 AM   #37
Knight72
I hooked them from the outside through the hole at the bottom of the stake pocket
Build thread:
Old 05-09-2018, 09:16 AM   #38
hotwls13
Thanks again. My process will be lift the bed off the sawhorses and roll the truck underneath bed (not rolling bed/lift). Have a few more things to button up with tank vent, etc. Then plan to have the bed on and secured by end of weekend.
Old 05-10-2018, 09:40 AM   #39
hotwls13
Well, I tried the straps way last night. Picked up some longer/stronger straps at HD.
Put one strap to front 2 stake pockets, one to middle stake pockets and one to rear pockets.
Couple problems....
This raggedy/rusty bed wasn't having it. The center drivers side stake pocket came loose at the bottom. I ended up not being able to use the center pockets for fear of doing further damage to the pocket/bed.
I was able to lift the FRONT of the bed. The rear stayed on the sawhorses the whole time. I think the front of the lift ram and the back edge of the bed are creating a fulcrum (pivot point) which isn't allowing the rear to raise.
Tons of tension on the straps (obviously). I didn't really like how the front strap was on the lift hook either. I'm going to get a heavy duty D-ring, put all the straps in that, then hook that to the top link on lift chain. That will give me another 6" of lift and make everything more secure.
I think I'll be able to install the bed this way. Just lift the front with straps, remove front sawhorses, roll truck under, set front of bed down on truck, get front two bolts in, move lift towards back of bed, lift back, remove rear sawhorses, then drop the back on.
Geesh, I should just call a bunch a guys over. haha, I was trying to get this to be a easy one man job but it's becoming a pain.
Old 05-11-2018, 04:54 PM   #40
mikecaddy500
mikecaddy500's Avatar
Buy 4 10 ft chains with hooks from menards. hook to hole in bottom of stake holes , front right to back left and opposite. you can slide lift forward or back to balance the bed.
mikecaddy500 is offline   Reply With Quote
Old 05-11-2018, 07:44 PM   #41
RichardJ
The center of gravity of the bed is a fixed point. You can't alter that by using cloth straps, wood braces or if you welded a lifting hook on the bed at a point which would be the bed's center of gravity.
If the straps are pulling the bed apart, because the angle of the pull, that would obviously be a bad choice.
Try lifting with the wood and adding a bucket of water to the rear of the bed. Assuming the total weight of the bed, wood and water doesn't exceed the total lifting capacity, you should be OK.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 05-11-2018, 08:01 PM   #42
hotwls13
After messing with the straps a bit (and also adding a heavy duty d-ring to keep straps contained) I think I’ve got it almost balanced. Front is lifting first but back right after.
Won’t get to putting the bed on til next week though. Found a bunch more to do on the truck before the bed goes back on.
Old 05-23-2018, 01:47 PM   #43
hotwls13
Finally!!
Well, the bed is back on!! Used the lift and I had my SOn and Father in law to help guide things. It was a little tougher than your typical install since 3 of the bed bolts are captured between the two welded floor panels.
This bed is in such poor shape, I'm pretty sure I'll be doing all this in the future once this truck is running/driving (so I have something to pickup a new bed with).
I think a combination of wonky, beat up bed, and maybe worn cab mounts and things don't lineup that great. I tugged, pulled, etc etc (all while only having bolts hand tightened and very loose). No wiggle room to get the bed slid over. Where it sits is gonna have to be good enough for now.
Onto the next headache, getting the fuel fill line to work. UGH!
Old 05-23-2018, 03:56 PM   #44
71sierragrande
Petroleum User
71sierragrande's Avatar
If you can afford a few 2x4's, you can lift almost anything. Make four A frames and join two each at the apex with a 45 cross brace(think of two swing sets parked right next to each other). Strap from four stake pockets and yank it up. Re-use 2x4's as needed and it didn't cost a dime.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
