Braided PS lines
For those of you who have upgraded to braided PS lines, where do you recommend getting them from? Did you use AN (Aeroquip, Russel) fittings as well? What did they run?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
Mike,
I used Earl's Teflon (not rubber) braided line. Steel fittings are around $5-6 and up to $20 some for the 120 degree on the master cylinder. Looks a heck of a lot better than it did. I don't know if I would use braided for a regular power steering setup if I didn't have hydroboost. For the return line, I just used Earl's super stock hose. Very good quality. Good luck.
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
cool thanks.
