05-23-2018, 10:18 AM | #1 |
LQ4 swapped K10 belt chirp
Ever since I completed my swap my SERP belt gets particles lodged in the grooves and causes it to chirp...yes is drives me nuts. It was a new belt 5000 mikes ago. Power steering pump and alternator have both been changed due to leaking and not working. I think the tensioner is shot. I can easily take off the belt with a regular length 15mm wrench. If I wire brush the underside of the belt then it’s good for a couple of days.. pulleys look to be lined up ok, although I did have the crank pulley off to do the front main on the engine stand. Thoughts?
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
05-23-2018, 11:10 AM | #2 |
meowMEOWmeowMEOW
Re: LQ4 swapped K10 belt chirp
Particles of what? Is it just road gunk, or do you have something in the vicinity corroding?
Most of my belt slip/noise on trucks has always been either P/S or Alternator related. Sometimes the alt can start to wear and stick, causing the belt to slip. Any flat spots on it?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-23-2018, 03:51 PM | #3 |
Nothing corroding that I know of... don't know what those particles are made of.
Water pump, power steering pump, and alternator all new to the truck.. Junkyard new that is..
05-24-2018, 05:18 AM | #4 |
Is the power steering pulley pressed on flush with the shaft of the pump?
05-24-2018, 10:20 AM | #5 |
The PS pump is new to the truck...took it off a smashed Tahoe at a wrecking yard ..I got bracket with it so I didn't have to pull off the pulley...truck chirped before and after pump swapped. I picked up a new tensioner and belt yesterday. I will install when I get home and we'll see..
05-24-2018, 10:38 AM | #6 |
Sounds like something is misaligned. I have had some set ups that just never quieted down no matter what I tried, but a Goodyear Gatorback belt has fixed them. https://www.amazon.com/Continental-E...gatorback+belt If you were to take your car to a professional shop, and they couldn't get it fixed within a reasonable amount of time, this is what they would use too. Quietest belt available.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
