Old 05-24-2018, 12:28 PM   #7
Free Candy Inside
Re: 66 C50 Cummins build aka Big Stupid
Originally Posted by Dieselwrencher View Post
Very cool project! If I were you I'd be getting some poly type engine mounts for this. Your trans is a 47RH if it came from the same truck. Very good trans and can be operated with toggle switches if you'd like.
Yes sir! Did the energy suspension engine mounts already. Also put a new tranny mount on it as well. When you do the toggle switch thing do you still run the factory computer with the 47re? I was also going to order up a Lokar 727 shifter for it.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
