05-25-2018, 07:38 AM | #1 |
Rear spring hanger
Where can I buy the piece that bolts to the frame that holds the front of the rear spring? I have one that needs to be replaced on my truck.
05-25-2018, 09:19 AM | #2 |
Re: Rear spring hanger
How urgently do you need one? I am going to be removing a set of hangers from a rust free frame from GA in the future - but it may be a couple months before I take them off. I am also in Iowa - NC IA.
05-25-2018, 11:40 AM | #3 |
Make sure the set-ups are similar. There are slight variations between 2wd/4wd/C10/C30 etc....
05-29-2018, 08:59 AM | #4 |
LMC has them for the 4wd trucks. I think that may be the only place.
05-29-2018, 09:47 AM | #5 |
The ones I will have are from a 87' Short Box C10 2wd.
