3 point seat belts
I just noticed that I have a bolt hole in both somewhat upper corners of my cab, I was wondering if anyone has used these to install a set of 3 point seat belts. I curently only have one seat belt and it is on the passengerside and I have no idea what it came out of. I figured while I have the bench seat out at the moment I would put a set of seat belts in it but would also like to install a set of 3 point units in it. Any one done this and what models did you getr yours from?
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
![]() Join Date: Feb 2000
Seat belts out of an S-10 work, although they are slightly short so if you are big in the gut they may not work for you. The passenger side will fit where the old belts bolted. The drivers side would except fo the gas tank is in the way, so you will probably have to drill a hole to mount it.
You may have to bend the mounting plate on the S-10 belts to make them sit level (so they work correctly). There are also Custom Belts on the market that you can buy. I believe the bolts for the shoulder brackets are 7/16" Fine Thread. Good Luck and get some belts in there! |
More Cowbell....
I installed a set using the hole in the wall. I got a set of 3-pointers from Chevy Duty. I don't really like the latch. It's not a push button type, but rather a lift latch type similar to an airplane seatbelt latch. If you catch it on any article of clothing, you are UN-LATCHED going down the road. When I switch out the seat, I will be ditching these as fast as possible.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Formerly yellow72custom
I bought a pair of 3-point belts from a lae 80's standard cab S10 for my truck. Hands down the best mod i have done...i feel 10x safer with them.
The passenger side retractor and buckles were a direct bolt in. I used the stock hole and bolt in the floor, and put in a bolt in the threaded insert in the cab roof. The buckle went right in place of the stock and was the prefect lenght too, not too short. The driver's side was almost a complete bolt in, except i had to drill a hole more forward in the cab floor to bolt down the retractor. I used a big washer, although i proably need to upgrade to a bigger one. It took me about an hour to get everything end and cost me $30 for the belts plus a few dollars for some grade-8 hardware. Completely worth it.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
I really wanted to get 3 points in mine so as soon as I got the thing I got a nice set of push button, self retracting types from Rick's Pickup Parts. Went right into the old mounts and the top corners. Real happy with them. I saved the origianls in case I ever sell the thing and the next owner wants to take it back to stock.
Mike
I did the same.Rick's hooked me up with blue 3pts for my suburban.I am a big guy and the belts fit fine.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Thanks guys for the responses, I checked out Chevy duty's price a little high, tried Rick's but couldn't find anything about seatbelts, went to the junkyard today and looked over some different vehicles including some S10's that were all faded or rotted out and decided to order some from Wesco Performance plus I also ordered a center seatBelt as well and all required hardware. Will have it here tomorrow.
Be very choosy with used belts. When they wear and dry rot the aren't very good. There is a reason racing belts have dates on them, and they are not legal after 2 years. It's small insurance.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
belts
I got mine from Gem Street Rods. gemstreetrods.com
fleetimus
68 Chevy l/b, 4 whl disc in the foothills of No Calif |
Hi,
I am a newbie. I bought the complete set of thre points and center belt from Early Classic for 219.00 Bob |
#11 | |
Shawn 1877 641-1387 |
Shawn,Got pics You can post? Thanks,Mike
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
Also, do you have a charcoal or dark grey color for those seat belt sets?
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 ![]() 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 |
Shawn,
Second request for pics. Will I be able to use all original holes? Is hardware included? And these are retractable right. What kind of latch do they have?-- Regular button style I hope ( not the aircraft type mentioned earlier) Thanks, Tom
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
#15 |
Pics
I looked thru all of the pics I have and I guess I never took any and I don't have access to any trucks we have installed them in right now. The only gray is a medium gray color, and they are the button type of latches. There are a few members that have installed them if they read this maybe they could snap a few pics for you.
Shawn Last edited by rickspickuppart; 05-07-2004 at 11:08 AM. Reason: I cant type for SH*t |
#16 |
Ok, so who's got some nice pics of Rick's Pickup Parts belts in your truck?
Please... ![]()
#17 |
Blazerless:-(
Rick- Are these the belts you sell??
These look grey, but are actually black. Diane |
#18 |
i got mine from a '80s suburban...they are longer than the s-10 belts...no cost to me as the guy was parting the 'burb and we give him a lot of business. we had to drill holes to mount the base but thats not abig deal...just make sure that what you get them out of wasn't wrecked or they would have been stretched and are no good.
-Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
#19 |
Next project: 1970 K10
For a little more money, here is a sweet option:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#20 |
1970blazin and possibly Rick's Pickup Parts
![]() Does that setup need a separate non retracting lap belt? I'm trying to picture what it would look like installed... Anyone else have pics? Oh yeah, sorry I guess I've become a highjacker ![]()
#21 | |
What are those seats from? I want a set! ![]() |
#22 |
Blazerless:-(
TomsC10R- The female end sits in the bench seat, or can hang in the console with the seatbelt holder. The male end just bolts into the stock hole in the cab and you have to drill a hole or make a bracket to bolt down the retractor. I will try to find a pic installed.
#23 |
Blazerless:-(
Here is the web page where you can see installation for this setup...I figure the vendors on the board are probably the better place to buy.
http://www.julianos.com/how2_67chevy_truck.html |
#24 |
Blazin,
Thanks for your help and the link!!
#25 |
My other Love
tha seat came out of a 98 and up chevy Silverado
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
