Old 05-29-2018, 10:01 PM   #1
CAJ1971
Converting to Power Brakes
My 71’ was factory with disc drum manual brakes. I want to switch to power brakes. Will buying one of these kits off eBay be ok or is there a better option?
The brackets on the ones I see on eBay say the bolt patterns are squared at
3 3/8”, but the studs on the fire wall are not 3 3/8” measureing from top stud to bottom. They are I believe 2 5/8”. What do you guys recommend?
CAJ1971 is offline   Reply With Quote
Old 05-29-2018, 10:59 PM   #2
cornerstone
cornerstone's Avatar
Re: Converting to Power Brakes
Are you measuring from centerline to centerline? If you measured the space between the holes I think you would come up with something close to what you mentioned...
cornerstone is offline   Reply With Quote
Old 05-29-2018, 11:11 PM   #3
CAJ1971
I measured from center of stud to center of stud. 3 3/8” from side to side and
2 5/8” from top stud to bottom stud.
The ones I see for sale on eBay say they are 3 3/8” side to side and top to bottom
Old 05-30-2018, 10:48 PM   #4
BCOWANWHEELS
Just get all stock 71-72 stuff from board member
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-31-2018, 05:59 AM   #5
custom10nut
custom10nut's Avatar
Like he said. Get a factory set up, plenty of board members have the available.
To my knowledge the mounting brackets for the boaster are not made in the after market, and neither are the support brackets
custom10nut is offline   Reply With Quote
Old 05-31-2018, 07:07 AM   #6
flashed
Frank ,member here sells new ones that are more powerful than stock , very nice units too.
flashed is offline   Reply With Quote
Old 05-31-2018, 08:54 AM   #7
Bearhawg
Bearhawg's Avatar
If you are interested, I have a factory booster, master and valve setup you are welcome to. It's off a 1970 c10 with four wheel drums. It was a dealer installed option. I cant speak to the fitment to a '71. I converted to power disc.
Bearhawg is offline   Reply With Quote
Old 05-31-2018, 02:52 PM   #8
aggiegrad
aggiegrad's Avatar
I put this one on my 68 and it bolted right in. Can't beat it for the price. It sticks out further from the firewall and had to stretch the lines. No complaints.
https://www.summitracing.com/parts/s...5-c1500-pickup
aggiegrad is offline   Reply With Quote
Old 05-31-2018, 04:09 PM   #9
JWSmith
not trying to hijack the thread, but I have a 70 that I switched to front disc, rear drums. I am in need of a brake booster and I am unsure which to get. Any help is appreciated...
JWSmith is offline   Reply With Quote
Old 05-31-2018, 04:20 PM   #10
BCOWANWHEELS
71 or 72 c10 trade your drum m/c and booster in as cores
Old 05-31-2018, 04:33 PM   #11
JWSmith
truck unfortunately didn't come with them, but I have the MC with the 5 lug conversion kit
Old 05-31-2018, 04:47 PM   #12
C-ries
C-ries's Avatar
Was researching making a similar upgrade to my '71...the parts store brake boosters don't appear to come with the mounting bracket to the firewall (they apparently assume you already have one).
This one from Summit Racing has the bracket on it. Haven't verified if the bolting pattern is correct as I don't plan on buying and making the change until this winter...which in South Dakota could be next week!
https://www.summitracing.com/parts/sum-760197
When I was looking into this a couple of months ago, I also had noted to get a new proportioning valve...this is the one I had noted:
https://www.summitracing.com/parts/clp-pvks-2
Last edited by C-ries; 05-31-2018 at 04:50 PM. Reason: Forgot link to proportioning valve
C-ries is offline   Reply With Quote
Old 05-31-2018, 05:16 PM   #13
JWSmith
I got the original brackets and my kit came with the valve. I am just missing the booster.
Old 05-31-2018, 06:20 PM   #14
aggiegrad
aggiegrad's Avatar
That is the one I installed a few months back and it bolted right to the firewall of my 68.
Old 05-31-2018, 10:43 PM   #15
CAJ1971
Thanks guys. I had planned on going to Summit and after seeing these replies for summit I think I’ll take the short 30 mile drive to the new store here in Texas and see what I can find.
Dang I hate that they put that place so close to home. Taken all my 💰 💴 🙄
Old 05-31-2018, 10:48 PM   #16
Jason Banks
Jason Banks's Avatar
That looks exactly like the one I got from ebay for $175 except I got a proportioning valve also. It fit and worked great.
https://www.ebay.com/itm/1967-1972-C...-/330948170372
I'm editing to say I see the other response here where the prop valve costs another $75....Makes my ebay deal look awesome. I will say...I did drive over to the new Summit store to get this: https://www.summitracing.com/tx/parts/clp-pv-tool Proportioning Valve Tool after I was unsuccessful at bleeding my brakes without it... My ebay kit didn't come with it. Some of the CPP kits come with it. I'm guessing summit and 'Tom' get their stuff from the same Chinese factory...
Jason Banks is offline   Reply With Quote
Old 06-01-2018, 01:00 AM   #17
cornerstone
I feel your pain. Even though they have free shipping on orders 99.$ I still find myself doing the 40 minute drive and walking around in a fog, daydreaming, kinda like my wife does at an art supply store. lol.
Old 06-02-2018, 01:35 PM   #18
JWSmith
curious as to if this booster will work
https://www.ebay.com/itm/GM-Power-Br...19.m1438.l2649
