No Limit R&P Steering Shaft Angles
Has anyone who installed the No Limit rack and pinion had any issues with steering shaft/u-joint angles?
I've installed it in my 70. Did it by the book. Moved the engine back to the rear mounts. Bought the recommended ididit shortened column specifically for the rack and pinion setup. Didn't deviate from the instructions whatsoever. Problem is my u-joint down where the long shaft goes to the short section at the frame has such a sharp angle it has tight spots. I cant figure out why or what I can change/adjust to correct it. I'm thinking the solution might be to get a double u-joint but then I need to support the long shaft off the frame. I want to measure my angles at the joint but didnt think to do it before I put the inner fender back in so now its going to be a pain to do so. Anybody else had this issue or is this just another thing on my truck that is somehow different from all the others?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
![]() Join Date: Jul 2010
Re: No Limit R&P Steering Shaft Angles
can you post some picts? maybe we can help.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
Here is one I have Rob. Let me know what else you need to see.
I can't adjust the angle of the column, nor can I adjust the angle of the shaft coming up from the R&P through the frame. Not sure why I am having this issue.
![]() Join Date: Jan 2011
John I ran into this a couple of time doing drag cars and what I found was just a little core shift on the jount bodies causing a little more material on one side. As the angle got up they would just rub. Marked where they touched with a sharpie and took a tiny bit off with the grinder. Worked fine after that.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
looks pretty good. These U-joints can go to 30 degrees OK. check to make sure the shafts are not protruding into the U-joint center, and touching. Also, I know the set screws are sometimes an issue. One long/one short. I usually cut the long one down to match the short. Make sure the set screws are not rubbing on the frame/mount bolt when rotating the steering. Last, check PG's solution. I have also fixed many steering issues with some light clearancing with a Dremel tool. Please let us know what the solution is. Thanks.
#6 | |
thanks!
#7 | |
I do have the shafts flush in the u-joints- I was careful to do that on installation. I did get rid of the long set-screws and installed shorties so I know it's not that. I may clearance the lower u-joint some more but am just surprised/disappointed that it's necessary. Something about this truck... Nothing ever goes easy. Its always got to be the hard way. I'll let you guys know how I resolve it when the column goes back in (had to drop it to remove my brand new dakota digital HDX cluster - it was bad from the factory and had to go back to DD for repair- like I said- nothing on this truck is ever easy). thanks
I dremeled the u-joint some more and got the clearance I needed. Certainly not the best way to fix it but it worked.
Glad to hear it is fixed. Did you measure the shaft angles? I know using the dremel here seams a little out of place, but that is hot rodding.
#10 | |
I installed a Turn One type II pump to work with it. I'm trying to sort out where to mount the remote reservoir and what I need to do for lines now. I'm very anxious to see how its going to work.... If everything works as it should and all my geometry is good, it should steer fantastic.
