06-04-2018, 12:30 PM | #1 |
CPP adapter to use 3/4 center support bearing on C10
I ran across this the other day and thought it was a decent idea. Anyone use one yet?
http://www.classicperform.com/Store/...Truck/CSBC.htm
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-04-2018, 02:41 PM | #2 |
Re: CPP adapter to use 3/4 center support bearing on C10
Have not used one, did not know such a part existed.
The design still utilizes the 2 inline bolts that hold it to the cross member. Not the best way to mount that deal. That improved part looks like it might be a little more sturdy...maybe... |
06-04-2018, 04:41 PM | #3 |
My thought is the 1/2 ton one breaks apart, and the 3/4 will be more durable.
06-04-2018, 06:58 PM | #4 |
Good enough idea I suppose, why wouldn’t you just remove the wimpy half ton support bracket and install the hd driveshaft bracket, half tons with a big block use the 3/4 ton style bearing and driveshaft.
06-05-2018, 04:50 AM | #5 |
The porterbilt crossmember allows the conversion. Did it on mine.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
06-05-2018, 09:11 AM | #6 |
Bought one thinking I could use my 3/4 shaft in my half ton.But the holes on my bracket were much narrower than carrier bearing holes. Also part seemed very thin almost sheet metal thin. So I ended up making my own with some 1/4” plate. So far so good.
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. |
