Kickdown cable.
I put a new 1" carb spacer under my 1406 on my performer intake, and for the stud pattern to match up i had to change the position of my kickdown cable. The bracket had to move back about 1/2", causing the cable to be tighter. Will this mess anything up? it seems to kickdown a little harder and sooner now, and hold the shift a little longer. Will this mess anything up? its on a th350 btw. thanx guyz
dale
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
Adjust your cable by the spring in back pull up clip, open throttle wide open lock clip back down . the clip might be pretty stubborn up and down but you will know when it is loose and locked.
