Closed Thread
Old 06-06-2018, 08:46 PM   #6801
Jim Boy
Smile Re: What did you do to your truck today? Chapter II
Too much sun will do it every time. It happens eh. Better times ahead. Have a good one.
Jim Boy is offline
Old 06-06-2018, 09:50 PM   #6802
NoStopN
NoStopN's Avatar
I swapped out the sealed beams for some LEDs today. I am not done with them yet, so I don't have any nighttime shots.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 06-06-2018, 09:53 PM   #6803
88gtstreetrod
[QUOTE=NoStopN;8276343]I swapped out the sealed beams for some LEDs today. I am not done with them yet, so I don't have any nighttime shots yet.
Very cool, whats involved with making that switch?
88gtstreetrod is offline
Old 06-07-2018, 01:16 AM   #6804
cornerstone
cornerstone's Avatar
I finally finished my Detroit Tru-Trac and 4:11 gear install! Its one of those jobs that has always intimidated me. I also got the rear disc swap finished
cornerstone is offline
Old 06-07-2018, 09:59 PM   #6805
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Put the last coat on this half hour ago.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 06-07-2018, 10:31 PM   #6806
NoStopN
NoStopN's Avatar
Four 5-3/4" LED lights. That's it. I had a problem with one of the retainer rings being bent beyond repair & got a new set yesterday. I also went to Home Depot to get some stainless screws to replace the regular ones that were rusted to the headlight buckets. But, tonight was all about the results.
Low beams:
High beams:
NoStopN is offline
Old 06-08-2018, 07:48 AM   #6807
Redneck Rydes
Redneck Rydes's Avatar
Those lights sure got Fluffys attention,lol, they look great.
Redneck Rydes is offline
Old 06-08-2018, 07:28 PM   #6808
71CHEVYSHORTBED402
Just finished a coat of paint on my engine block. Took over 2 hours to brush it on. Another two coats to go.
Not worth a picture yet, but these might be. I picked them up earlier in the week. The original hardware and replacements were zinc coated black & clear. Of all the original hardware I sent, just four didn't come out right. Two didn't come from this truck Either the threads were pitted, or I missed some lock tite, I'm guessing.
On a side, not a fan of the "boss" where I had them done, and neither are his employees. I read that loud and clear before he "decided" to show up. After the fact he says black oxide is more durable than zinc plated. Course they don't do black oxide, he just thinks he knows something, and perhaps he does. I've read zinc is more durable than oxide, and for that matter, more durable than magnesium phosphate (original) too. Who knows.
Turns out black oxide is five minutes from me. I stopped before and asked if they did oxide or phosphate, and was told nope. Probably didn't speak English......ha. Doesn't matter, the zinc came out better than I imagined.
Tony
Old 06-08-2018, 09:38 PM   #6809
SoCoC10
SoCoC10's Avatar
Giving the one owner K20 Cheyenne some much needed attention. Found these gems. jack, jack tools and jack instructions. Original carpet with carpet tag.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 06-09-2018, 07:57 AM   #6810
robs71
robs71's Avatar
Installed headliner,Dome and cargo light, cab roof lights........
robs71 is offline
Old 06-09-2018, 11:58 AM   #6811
71CHEVYSHORTBED402
Beautiful build
Tony
Old 06-09-2018, 01:48 PM   #6812
NoStopN
NoStopN's Avatar
I'm sure the Cherry Bomb muffler helped in getting their attention. The bigger 2 dogs were behind a fence.
NoStopN is offline
Old 06-09-2018, 05:57 PM   #6813
robs71
robs71's Avatar
Thanks Tony...
robs71 is offline
Old 06-09-2018, 08:21 PM   #6814
Quikshft
Quikshft's Avatar
I snagged these on ebay this morning. Already have the bedside pieces.
Quikshft is offline
Old 06-09-2018, 09:58 PM   #6815
Metaldoc
Metaldoc's Avatar
Low beams:
High beams:
Man I tell you there's a difference between low and high beams. You couldn't even see that dog in the low beams. LOL
Metaldoc is offline
Old 06-09-2018, 10:30 PM   #6816
yuccales
yuccales's Avatar
Had to do a radiator today. The old one had so many tubes cut and soldered, surprised it would cool. It let go in a big way yesterday. Got a Murray plastic & aluminum one at OReillys. Not a big fan of "made in china" but I needed it fixed today. It was a direct fit, no problems, no leaks. Trans cooling lines threaded right in. It does have the heater hose nipple in the tank, but came plugged and sealed already. If you need a cheap, quick fix, NOW, not a bad radiator.
yuccales is offline
Old 06-10-2018, 07:15 PM   #6817
71CHEVYSHORTBED402
Finished this a few hours ago. Many hours brushing it on, three coats. Sick of painting too, primarily because yesterday might have been the windiest day in a year. Never-mind the allergens, I couldn't role up either door, so add poor ventilation. Stomach woke me up at 4:30, because my sinuses were shot.
Edit: Might be worth mentioning, 1/2" rectangle foam "cleaning swab" sticks work real well for tight places. In hindsight I'd have used them more than I did. I used those with a good 1" brush.
Tony
Old 06-10-2018, 09:21 PM   #6818
imholte
imholte's Avatar
Love the lights, I have the same ones. Would love to see more of your truck, mines he same color, just a lot of patina added...and rust too. Can’t wait to see more
72' Custom10 4wd 350: Daily Driver
imholte is offline
Old 06-10-2018, 11:44 PM   #6819
KQQL IT
At the body shop.
KQQL IT's Avatar
Made laps to my brothers house.
And blew his 78 apart.
Going to be cool
KQQL IT is offline
Old 06-11-2018, 12:01 AM   #6820
Knight72
Picked up a set of second hand world products sportsman heads with stainless valves for $325 to replace the swirlports on my 350
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline
Old 06-11-2018, 09:20 AM   #6821
Chrome8
Chrome8's Avatar
I mounted and balanced 4 new tires and wheels. Ford Steelies and 255/85/16. I found that stick on weights will not clear the calipers in the front and I also found that it's been so long since I mounted tires that I had to go to YouTube to figure out how to use our new machine. Now time to find some hubcaps!
1969 K20 not running, complete but rusty with wrecker boom and push bumper
1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina"
1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed
"Choose a job you love, and you will never have to work a day in your life."
Confucius
Chrome8 is offline
Old 06-11-2018, 11:28 AM   #6822
UNEASYRIDER
UNEASYRIDER's Avatar
Back to normal!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 06-11-2018, 03:53 PM   #6823
Boog
laying low
Boog's Avatar
Did you straighten the grille surround or replace it? Looks good again.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 06-11-2018, 03:57 PM   #6824
OregonNed
OregonNed's Avatar
Looks great!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 06-11-2018, 05:18 PM   #6825
71CHEVYSHORTBED402
Going to be cool
How come you do in a day what took me 1.5 years?
Man, hub caps are going to be the finishing touch, Awesome rig
Tony
Closed Thread
