Old 05-29-2018, 11:02 PM   #1
NJKelly
Headers recommendation
My blazer has a 350 with headers that do not have room for the drive shaft for the front differential. I have considered removing headers and placing the ram manifolds with flowmaster exhaust. The truck will be going 40 miles an hour at most when I drive it at the beach, and I wonder about the best exhaust manifold setup to use. I'd like to reinstall the drive shaft so it does have 4-wheel drive and will consider putting in headers meant for that if there are advantages to them over stock exhaust manifolds. Thanks for your answers.
NJKelly is offline   Reply With Quote
Old 05-30-2018, 07:46 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Headers recommendation
with a stock motor...headers are more trouble than they're worth...good rams horn manifolds will be much less hassle.... just my 2¢.....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 05-30-2018, 08:22 AM   #3
NJKelly
A guy near me has a set on Craigslist for $30. Are they prone to cracking or warping, I wonder if new remanufactured ones will be less trouble.
Old 05-30-2018, 09:19 AM   #4
A1971Blazer
A good factory set would be best...they aren't prone to warping and cracking but it can happen....usually a visual check will reveal a crack....and a straight edge will verify flatness....a good set of metallic gaskets will seal them very well.....torque them down and after a few hours of running...torque them again and forget them...
1967 C10 Step side
1968 C10 Step side
Old 05-30-2018, 12:06 PM   #5
NJKelly
Maybe I'll grab those on Craigslist then, thanks for the help.
Old 05-30-2018, 12:10 PM   #6
A1971Blazer
If they're good-----$30 is a decent price
1967 C10 Step side
1968 C10 Step side
Old 05-30-2018, 12:18 PM   #7
SeventyOne
Stock manifolds, or the 2.5" corvette manifold are a common upgrade.
And if you REALLY want headers (which I can't blame anyone and I run them as well) I think Sanderson makes really nice quality headers that wont leak if installed correctly.
SeventyOne is offline   Reply With Quote
Old 05-30-2018, 08:50 PM   #8
WAYNE G.
I have a new set of headers for a blazer that I will not use they are Holley Flow tech 11500FLT that fits. Let me know. Thanks Wayne G.
WAYNE G. is offline   Reply With Quote
Old 05-30-2018, 08:53 PM   #9
NJKelly
What are you asking for them?
Old 05-30-2018, 09:27 PM   #10
simicrintz
X2 on the Sanderson's. Run them on my Jeepster and they have been on two different engines; never had a leak.
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 05-30-2018, 10:07 PM   #11
WAYNE G.
I would use EARLS HEADERS GASKETS have them on my 69 camaro and not one issue
Old 05-30-2018, 10:50 PM   #12
WAYNE G.
Sent you a pm
Old 05-31-2018, 11:51 AM   #13
NJKelly
Never got the PM Wayne
Old 05-31-2018, 08:36 PM   #14
Mike C
Mike C's Avatar
Driveshaft interference suggests someone put a set of two wheel drive headers on the truck.
IF I was going to run headers again, they would be Heddmans again. Back in the late 80's they were the only ones that would clear the clutch linkage I could find. Got tired of returning crappy ones to Super Shops.
But I went to the 'vette 2 1/2" outlet manifolds on my Jimmy and we are doing the same on my kids Jimmy project. They work great, look great, are low to no maintenance and are cost effective at $120 from Speedway motors. Available other places as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 05-31-2018, 09:05 PM   #15
WAYNE G.
I tried to pm again. Total is 125.oo shipped. Let me know if you need them. Thanks Wayne
706-399-4060
Old 05-31-2018, 11:48 PM   #16
NJKelly
So their Hedmans that are made for a Corvette, do I understand you correctly? Do you have a part number? Thanks
Old 06-04-2018, 10:31 AM   #17
Mike C
Mike C's Avatar
If you are asking me, the part # I used for headers was for a 67-72 4x4 with manual trans. You can get that by calling Summit or Jegs to order.
But on my truck I used the reproduction cast iron Corvette Rams Horns with the larger 2 1/2" diamter outlet. Mine came from Speedway Motors.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-08-2018, 06:03 PM   #18
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Unless you're making north of 350hp, gains with headers wouldn't be realized. And the extra effort just for the sound of headers isn't worth it, IMO. The headaches of leaking gaskets and fasteners coming loose constantly are another negative.
I'll reiterate the corvette ram horns will flow plenty for a stock-ish Chevy small block, as there are a few flow comparisons over the years by different magazine writers. PLUS, they're relatively cheap, and can be installed in under a six-pack worth of time.
Jason
Cap'n Hook is offline   Reply With Quote
