Old 06-10-2018, 10:40 PM   #1
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Exhaust manifold question
Can I use the straight down exhaust dump cast manifolds on a 327 in a 67 C-10 coil spring truck without any crossmember conflict? I am having built a 327 to produce 300 HP and thought I should use corvette fuelie 2-1/2" manifolds. Any input is appreciated. Thanks
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 06-10-2018, 10:43 PM   #2
chewychevy67
Re: Exhaust manifold question
I have looked into it and in a 4x4 yes it's easy. I have seen 2 2wd trucks done but it is extremely tight and good luck getting it off when needed. The bend is very tight right off the manifold.
chewychevy67 is offline   Reply With Quote
Old 06-11-2018, 12:46 AM   #3
Grumpy old man
Grumpy old man's Avatar
There's plenty of room ,These are 2 1/2" rams, 350 in a 67 short bed frame.
Old 06-11-2018, 01:23 AM   #4
BCOWANWHEELS
Room if youove engine n trans back
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-11-2018, 02:23 AM   #5
Grumpy old man
This was a L6 I removed the 6 manual cross member and installed a factory V8 stock manual cross member and used stock V8 engine mounts in the front holes, There's room for 2 1/2" pipes .
Old 06-11-2018, 02:38 AM   #6
BCOWANWHEELS
6 and v8 mounts are the same - except rubber engine mounts - just in different locations. you use the 6 cyl location with a v8 and theres room but engine is back further
Old 06-11-2018, 02:45 AM   #7
BCOWANWHEELS
I also polished n trimmed my 2.5 vette manifolds, it sure makes em look good
Old 06-11-2018, 02:57 AM   #8
Grumpy old man
I'm just setting mine up in the stock location . would there be more room if you used the 6 parts on the 8 ,Sure but it fits using the stock V8 parts
LockDoc posted these pics last year .
http://67-72chevytrucks.com/vboard/s...d.php?t=732393
Old 06-11-2018, 03:51 AM   #9
BCOWANWHEELS
that pic is priceless, thanks. I,d really like to meet you grumpy. I,am in Kingsport.
Old 06-11-2018, 08:16 AM   #10
So, did any small block 2wd trucks come with straight dumps or were they all from 4wds? My experience is mostly with 4wds and I assumed all 2wds used curved. I have some manifolds I need to identify, curved/straight and with/without alt/ac mounts
Old 06-11-2018, 09:56 AM   #11
BCOWANWHEELS
2wd is all curved
Old 06-11-2018, 10:28 AM   #12
OregonNed
OregonNed's Avatar
This a good article to look through on the subject. I contacted the author to confirm that the straight down Tru Ram manifolds fit ok.
http://www.hotrod.com/articles/1112c...et-c10-engine/
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-11-2018, 10:41 AM   #13
BCOWANWHEELS
those arnt gm manifolds...... in that article.
Old 06-11-2018, 03:12 PM   #14
weim55
One other thing to think about, I don't know if the Vette left manifold has the alternator mount holes but if it doesn't you could run into an issue using the stock 67 C10 alternator brackets. If you're cylinder heads have both holes on the end you could use the 71 72 truck alternator bracket set up that bolts to the head that way keeping the original short water pump set up.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 06-11-2018, 05:02 PM   #15
Grumpy old man
^^ That's what I did .
Old 06-11-2018, 07:13 PM   #16
I got a set of Sanderson shorty headers from a member who had them on a C/10. I trust him, but does that sound possible? Would the engine have to sit back in the 6cyl mount holes?
Old 06-11-2018, 07:55 PM   #17
Grumpy old man
If they are CC17's they will fit in the V8 location , A little pricey at $525.00
https://www.sandersonheaders.com/san...el-camino.html
Old 06-11-2018, 10:30 PM   #18
These are block hugger style, center dump.
Also, when you guys smooth the manifolds, do you mean just all the nubs and such or do you take ones with cast brackets and cut them out and smooth?
Old 06-12-2018, 04:58 PM   #19
BCOWANWHEELS
both
Old 06-12-2018, 08:45 PM   #20
Grumpy old man
A few pics from a 7 year old thread on 2 1/2 install
http://67-72chevytrucks.com/vboard/s...=440965&page=2
Old 06-12-2018, 11:39 PM   #21
BCOWANWHEELS
if you use tight mandrel bends and tig it all together you can do a nice job but it takes time, fitting etc. it also helps if you wrap the p/s pipe next to starter to keep heat soak out of it. there is no performance gain to 2.5 except for hi-compression engines. lastly make sure you can get starter off and on
Old 06-13-2018, 09:05 AM   #22
Originally Posted by BCOWANWHEELS View Post
both
Thanks again. I may smooth up on some old style ones I have if no one wants for original restoration.
Old 06-13-2018, 09:22 AM   #23
BCOWANWHEELS
blast them inside n out then have them surfaced flat, then see if you have to elongate mounting holes then polish. bbq grill paint does real nice also
