Fender Flaring
Guy's I need to flare out my fenders or space them out a bit as the new wheels and tyres I bought are just a little too tight.
Any suggestions on ways to do this? |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Fender Flaring
Fleetside, or Stepside?
Re: Fender Flaring
If you know a good bodyman that is good with a hammer and dolly the inner lip of the fender or bedside can be rolled in and you can gain some clearance that way. I did that on my 66 and got about 1/4 inch. Taking it slow will make it possible to do it without doing any body work or painting.
60-66 Nut
Re: Fender Flaring
Since you don't have your bed wood installed yet, you might consider widening the whole bed and inch or two. There was a former member here that did that to his stepside bed. I'll have to see if I can find his build thread.
Edit: I think his build thread here must be gone as I can not find it. This is the best I could do with a link to a thread elsewhere. http://www.67-72chevytrucks.com/vboa...d.php?t=452520
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-16-2018 at 12:06 AM. |
![]() Join Date: Feb 2013
Re: Fender Flaring
I used one of these and gained 1/2" of additional clearance on each side. I'm guessing you can do the same on a fleetside.
https://www.eastwood.com/ew-fender-r...SABEgL5ZfD_BwE You'll need one of these if you are running 6-lugs https://www.eastwood.com/fender-roller-adapter.html Last edited by mfm3; 05-16-2018 at 12:56 AM. |
Re: Fender Flaring
Re: Fender Flaring
#8 | |
Re: Fender Flaring
#9 | |
Re: Fender Flaring
Re: Fender Flaring
By way of a bit of an update, last night I bounced the bed as much as I could to see if the fenders came in contact with the tyres.
Now, Ok I know I don't have the bed wood in yet but equally Ive no shocks fitted. With the bed bouncing a good bit there was no contact. So I feel a little rolling of the inner lip of each fender should do the trick. It should be enough. Going to have another look tonight. |
Re: Fender Flaring
Had a good look tonight and I put the edge strip of wood in so it raised the bed up 1/2" and you know what it clears, only just but it does clear.
I guess if it was to really bottom out and the wheel come right up into the fender Id have a problem but I not offroading it. Its purely a fun/show truck. It will most likely have next to nothing in the bed other than a tent and supplies. I think it will be OK. I will bring the inner lip in a little though just to be sure and give a little clearance (still going to look at that Eastwood tool though). |
Re: Fender Flaring
Eastwood fender flaring tool, readily available in the UK! Yipee - for once!
Re: Fender Flaring
It may not be an issue, but if you have a short panhard bar, the rearend will have some side to side movement as you go over bumps.
Re: Fender Flaring
I formed 1/2" roundstock to the shape of the opening, rolled the sheetmetal around it, and welded it up.
