06-10-2018, 06:09 PM | #1 |
Modern take off wheels
I have a 1972 4x4 k 5 and my question is will modern 17” rims fit my blazer ? I see two things to look at bolt pattern and hole diameter.
06-10-2018, 06:35 PM | #2 |
Re: Modern take off wheels
Also look at offset, which I suspect will make the swap impractical.
06-11-2018, 09:33 AM | #3 |
My blazer has modern wheels, I had to machine the center bore to size as the centerbore on modern wheels are smaller.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
06-12-2018, 01:20 PM | #4 |
Vintage Evil
as mentioned center bore will be the biggest hang up with them fitting... but you might need spacers too...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
06-12-2018, 01:44 PM | #5 |
haven't taken any measurements or have any idea if anything was modified, but my 71 K20 burb with stock axles and hubs as far as I know, came with late model aluminum 8 lug wheels and all seems to clear fine..
good luck!
I started out with nothing - and I still have most of it |
06-12-2018, 04:27 PM | #6 |
Vintage Evil
8 lug wheels will all work fine... is the newer 6 lug wheels that have smaller bore...
06-12-2018, 06:01 PM | #7 |
^ thank you for clarifying that! the rusty blue k1500 is 6 lug and I may need this info later
06-13-2018, 04:47 PM | #8 |
Vintage Evil
No prob...
