10-21-2017, 12:14 AM | #226 |
Re: Hydroboost Mounting Plates
PM sent for Power Brake Booster Adapter Bracket and Hydroboost Mounting Plate. Bare steel.
10-21-2017, 12:36 AM | #227 |
60-66 Nut
I replied to your PM.
10-24-2017, 11:01 PM | #228 |
PM response sent for Power Brake Booster Adapter Bracket and Hydroboost Mounting Plate. Bare steel.
10-24-2017, 11:30 PM | #229 |
60-66 Nut
I replied to your new PM........
01-10-2018, 01:07 AM | #230 |
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
03-07-2018, 03:30 PM | #231 |
I have a 1966 chevy C10 and a 1999 chevy 2500 HydroBoost what plate and spacer do I need and will the brake rod on the hydro work Thanks Gary
03-07-2018, 05:46 PM | #232 |
Hey CaptainFab,
I saw you mention in one of your posts that this plate will work with your booster mounting brackets. Does that mean it's compatible with the booster mounting bracket (i guess it's more of a kit) that you make for the trucks that use the original master cylinder for the brakes and the clutch? Thanks! |
03-08-2018, 12:13 AM | #233 | ||
60-66 Nut
To mount your 1999 hydroboost unit you will need this booster bracket and the hydroboost mounting plate in this thread. Then everything will bolt together. However you will have to lengthen the hydroboost pushrod. There are a few ways to go about that.
03-08-2018, 12:36 AM | #234 | |
Thanks for the response. |
04-10-2018, 01:31 PM | #235 |
04-10-2018, 11:20 PM | #236 |
60-66 Nut
Sorry I do not understand the question?????????????????
05-28-2018, 01:48 AM | #237 |
Payment sent
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
05-28-2018, 11:29 PM | #238 |
60-66 Nut
Payment received. Do you need a booster bracket to mount this to the firewall correctly?
05-29-2018, 08:00 PM | #239 |
I have your bracket already so I believe that all I need is the plate for the hydro boost.
05-29-2018, 11:28 PM | #240 |
60-66 Nut
Yes that is correct. I just wasn't sure if you already had one of my booster brackets.
05-31-2018, 09:55 AM | #241 |
Yes sir I have 3 of them. Great brackets!
06-16-2018, 01:51 AM | #242 |
Its a Truck Thing......
Do you have any HB sockets for sale?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
06-16-2018, 01:53 AM | #243 |
60-66 Nut
Sorry but I currently am out of them. I could have more in about 9-10 days.
06-16-2018, 01:59 AM | #244 | |
Smitty
06-16-2018, 11:19 PM | #245 |
60-66 Nut
I do not have a '67-'72 standard booster bracket or a hydroboost mounting plate in stock in satin black powder coat. That will take up to a week to have done. I will send you a PM with ordering and payment info.
08-23-2018, 03:38 PM | #246 |
Subscribed
09-06-2018, 12:36 AM | #247 |
60-66 Nut
There seems to be a misunderstanding with some people that think that you HAVE to use a Astro/Safari van hydroboost unit with this hydroboost mounting plate. That is NOT true. You can use any GM hydroboost unit. Once you remove the factory mounting bracket, they are all interchangeable.
12-10-2018, 10:57 PM | #248 |
I would like a booster bracket and hydroboost plate for 67-72 please
12-10-2018, 11:43 PM | #249 |
60-66 Nut
I will send you a PM.
03-22-2019, 12:19 AM | #250 |
Hey Captain - Back with a new project.
I'm working on a 72' C10 that is currently power disc/drum, but I'll be converting to disc/disc. I'd like to run a hydroboost. I have a few questions for you and folks who have done this. 1. My understanding is I'd need your booster adaptor and hydroboost adapter. 2. Would I need the socket, assuming I buy a new hydroboost? I'm assuming yes, to mount it to the new bracket at least. 3. Do we know if modifications to the pushrod are needed with the adaptor/hydro-plate to reach the brake pedal, or do they typically have enough adjustment? Thanks all! |
