Old 06-16-2018, 07:59 AM   #1
NC_John
NC_John's Avatar
Lower rad hose? Entropy rad and truck water pump
I'm trying to fit the lower radiator hose I need for an entropy (swap) rad and a truck water pump. I saw on another thread it was a 20687 but it didnt fit (too long, angles wrong). Anybody have another hose I can try?
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 06-16-2018, 12:41 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Lower rad hose? Entropy rad and truck water pump
I assume you have a LS swap...on my lower hose I never did find one that fit....I took 2 hoses and a aluminum sleeve and made one. ..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-16-2018, 01:57 PM   #3
Ghost's68
Ghost's68's Avatar
Check out my build thread I have a part number for a hose that worked for me. I did have to shorten it but it worked great. I believe the 5th gen Camaro and truck WP are the same.
Ghost's68 is offline   Reply With Quote
Old 06-16-2018, 02:22 PM   #4
NC_John
NC_John's Avatar
Yes....with the truck accessories.
i thought the swap radiator would have the lower hose positioned the same (or very close) as a stock newer truck
1970 C-10 LWB "Blu"
Old 06-16-2018, 06:06 PM   #5
NC_John
NC_John's Avatar
I found it in your build thread. Looks like a Ford application hose.
I played around some more with the one I got and got it good and stuck on the water pump. So stuck I had to cut it off. Since it was now non-returnable I messed around and got it to fit by cutting off both ends. It's actually a tiny bit too short. I might buy another of the same one and trim it a bit more carefully. It was NAPA PN NBH7460.
1970 C-10 LWB "Blu"
Old 06-17-2018, 10:55 PM   #6
Curtb1971
Curtb1971's Avatar
I used a NAPA 9131 with the truck pump and entropy radiator. Had to trim some of the hose to fit but it ended up fitting great.
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 06-18-2018, 09:49 AM   #7
Steve Cole
Are the hose fittings at least the same size?
Steve Cole is offline   Reply With Quote
Old 06-18-2018, 02:41 PM   #8
NC_John
NC_John's Avatar
That looks like it might be a better fit than the 7460 I have on there now.
thanks
1970 C-10 LWB "Blu"
Old 06-18-2018, 06:37 PM   #9
Curtb1971
Curtb1971's Avatar
Yes, fitting on the entropy radiator and water pump are the same.
thanks
No worries, give her a shot. I went through the same dilemma and had a pile of hoses to return to Napa
Old 06-21-2018, 10:01 AM   #10
truckdude239
truckdude239's Avatar
i used a stock truck hose and cut the end down was little tight on the radiator side but a little lube it went on but i am using a stock truck motor and a cold case swap radiator
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 06-21-2018, 07:11 PM   #11
NC_John
NC_John's Avatar
Ends up that this hose is way too short for my setup. Your engine must be mounted a lot further ahead than mine. I've got mine as close to the firewall as I could get it.
1970 C-10 LWB "Blu"
