Old 06-16-2018, 10:30 AM   #1
Sawlog
2in wheel spacers?
This is my 69. I just can't get used to Chevys having there tires so far under the truck.
I would like to move my wheels out 2in. I have 15in aluminum 6 lug wheels.
I'm guessing wheel spacers are my only option? Not wanting to buy more wheels.
And are they safe? A owner of our local tire shop told me that wheel spacers are not safe because the weight is not on the hub anymore, it's on the bolts.
Also, if any of you have done this could you please post a pic? And tell me where you bought them?
Thank you
Sawlog is offline   Reply With Quote
Old 06-16-2018, 10:57 AM   #2
davepl
davepl's Avatar
Re: 2in wheel spacers?
I sure wouldn't go 2 inches, that's 4 inches in track width.
But I've got 1/2" spacers on mine to clear the hubcaps and I could have doubled them up for a full inch on each side. It does square up the look some.
It's totally arbitrary but I wouldn't feel comfortable going much more than a half to full inch per wheel. And of course you need longer studs and all of that.
Mine are 8-bolt and I got them on eBay.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-16-2018, 12:21 PM   #3
72LB
72LB's Avatar
Why not look for rims offset to the outside more.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 06-16-2018, 12:52 PM   #4
Sawlog
Those wheels are only a year old, don't really want to buy again.
It's hard to find 15in, 6 lug wheels with the offset to get the tires out.
Old 06-16-2018, 04:35 PM   #5
52napco
I've had 2 inch spacers on the back of my K20 for years with no problems.
52napco is offline   Reply With Quote
Old 06-16-2018, 05:38 PM   #6
88gtstreetrod
Running a 1 inch spacer with 20x10 and 5.5 backspacing with 5 inch rear drop. Don't think a 2 inch spacer made from the 6106 aluminum would be an issue..
88gtstreetrod is offline   Reply With Quote
Old 06-16-2018, 09:53 PM   #7
mike16
they look beautifull.
But you want spacers.
Be carefull. DOT becomes unhappy if your wheel failure reveals spacers and an accident involves injury to others.
Spacers change geometry and steering, They put a strain on other parts... including the wheel studs.
I had one fail on me. sent the wheel and tire combo down the center of the high way and across a few lanes of oncoming traffic.
The hardware needs constant monitoring and occssional tightening.
mike16 is offline   Reply With Quote
Old 06-17-2018, 11:09 AM   #8
davepl
davepl's Avatar
I don't think spacers are that big of a deal, within reason. Now, -adapters- spook me. But spacers not so much. I'd still keep them thin though.
Old 06-17-2018, 12:23 PM   #9
weq92f
weq92f's Avatar
88, which wheels are those?
I have the same "issue" and attempted to solve by ordering more backspacing from my wheel manufacturer. They informed me what I had was the max available so I too am running rather large spacers. The only other route with wheels was going to be very expensive.
Thanks,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-17-2018, 01:07 PM   #10
88gtstreetrod
Thanks,
-klb
They are the Riddler Wheels. I have two sets for the front. 20x8 with 4.5 backspacing and 18x8 with 4.5 backspacing
Old 06-17-2018, 07:34 PM   #11
BCOWANWHEELS
your asking for disaster, listen to the tire guy.............
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-17-2018, 10:32 PM   #12
ZEKE68
ZEKE68's Avatar
I have run wheel spacers over the years on different vehicles, VW's to 1/2 ton pickups and haven't had an issue doing it. The last ones I bought from Gaugemagazine.com. They are 6061-T6 material. With new wheels or adaptors you should torque them and back them off a couple of times before you torque them and run them. Recheck the torque after some run time. Then they should do well.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 06-18-2018, 09:25 AM   #13
It's not what the spacers are made out of that concerns me about using 2" spacers rather than the right wheels. It's the original design bearings, spindles, ball joints, and even the studs that were not made to take that stress that concern me. Leverage. The correct wheel with the amount of dish you want will also be wider with the correct amount of backspace to counter the offset.
Spacers are not the 'only' way to go. Correct wheels or get used to the look of these trucks are the 'only two options' for me.
