View Poll Results: Anti Corrision Inhibitors
Purple Ice 3 60.00%
Water Wetter 2 40.00%
Voters: 5. You may not vote on this poll
Old 06-15-2018, 04:14 AM   #1
toolboxchev
Coolant Anti Corrsion Inhibitors
After doing some reasearch I came accross 2 big names in the mass market. May turn this into a poll.
Which one is better?
Redline's Water Wetter
Royal Purple's Purple Ice
Lets hear it for the votes. And specifically why?
toolboxchev is offline   Reply With Quote
Old 06-15-2018, 06:31 AM   #2
Mikes68C10
Mikes68C10's Avatar
Re: Coolant Anti Corrsion Inhibitors
Drag racing community around here go Royal Purple.
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car.
1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof.
Mikes68C10 is offline   Reply With Quote
Old 06-16-2018, 10:44 AM   #3
toolboxchev
Keeping it fresh, found some stuff at NAPA and had used it before called NapaKool.
Appears to have a 2 percent Hydrochloric Acid in Solution with Nitrates and Nitrites.
So who can speak to block corrosion and prevention using these products.
Old 06-16-2018, 12:10 PM   #4
68Gold/white
I use the NAPA stuff on the fleet vehicles I maintain. I also use their coolant test strips to test, once a year.
Not sure what those others do, or what they are. The NAPA product is made for the common coolants that have been around for a long time.
68Gold/white is offline   Reply With Quote
Old 06-16-2018, 06:04 PM   #5
lil hoodlum
lil hoodlum's Avatar
I've used the water-wetter before several times.
I can't say if it made a difference or not. If I recall corectly, it is like $18 a bottle at my o'reillies or autozone.
lil hoodlum is offline   Reply With Quote
Old 06-16-2018, 09:49 PM   #6
mike16
some contents increase thermal transmission, other resist rust, others remove rust and scales.
flush it, remove scales and rust, add a proper mix with a water wetting agent. In the pontiac community I hear water wetter is good,
After flushing a system I have used CLR or Drano to remove any grease, stop leak, rust or what ever from the system. Drano will damage water pump seals and aluminum.
then a 50/50 mix
Drano will find any leaks. Dont blame it if your cooling system was about to take a &4#@) any way. Flush it out thoroughly or it will keep on working.
mike16 is offline   Reply With Quote
Old 06-17-2018, 01:29 AM   #7
toolboxchev
I went 2 years since the last coolant change using this product and still got rust. Must check my maintenance records sooner.
Anyone have better luck?
