AC Help
My 85 C10 has a 305/700R4.
The previous owner had the AC converted to R134. It cools pretty good but the compressor cycles off and on pretty regularly and the belt flaps a little even though it appears tight when I check it. Is there a fix for this? No idea how the conversion was done or if done correctly. I suspected the freon level might be low but when I put guages on it to verify, it reads a little high when the compressor runs then drops off when it cycles off (a normal indication I would imagine). Anyone have a fix for the compressor cycling?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: AC Help
It is normal for the compressor to cycle when things are setup correctly. You worry when the vent air is barely cool and it isn't cycling or it comes on for a couple of seconds then goes off for a while.
What are the vent temps with the fan on high? If yours is a V-belt setup, that long run from the compressor to the PS pump will bounce a little bit. |
Re: AC Help
Well, I didn't have a vent temp gauge so I ran down the road about 5 miles to the Napa to pick one up. Driving back doing about 55-60, vent temp never got down below 60F. Pulled into the driveway and popped the hood, compressor was running constantly and making a fast tapping noise, not super loud but still noticeable. I decided to call it a day, have some beers and step into Father's Day Mode.
It gets pretty hot here and with a black interior, I know there is only so much that can be done but it should be colder than that IMO. Thanks for the advice in advance.
Moderator
![]() Join Date: Oct 2008
Re: AC Help
Around 45 degrees vent temps is normal.
Knocking... clutch or compressor?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Re: AC Help
seemed like it was more like a ticking noise coming from the clutch.
Re: AC Help
LDO ride down here one weekend & we'll pop the gauges on there & see what's what!
Re: AC Help
Thanks man, I appreciate the offer. You are about 2 hours from me. I'll PM you and maybe we can set something up for next week!
