Old 06-16-2018, 12:19 AM   #1
cal0077
56 Apache
Hello everyone,
New to forum snf new owner of a project 56 Apache. First of many questions to come in can someone show me what the bottom of the inside of the beds look like. I think the previous owner took something off as I see a bunch spot welds that were drilled out...like maybe a lip was there? thanks
cal0077 is offline   Reply With Quote
Old 06-16-2018, 12:56 AM   #2
dsraven
Re: 56 Apache
post up some pics and we will have a better idea of where you are looking, front, rear, left, right?
Old 06-16-2018, 01:09 AM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 56 Apache
Raven is right, you DO need to post pictures for us to help you.
But I can tell you the only thing spot welded in the bottom of the bed is the angle strips along each side of the stock bedsides. But these trucks are over 60 years old now so many of them have been modified over and over in their long lives.
Mine had a 16” thick steel plate spot welded over the factory wood to the angle strips. I nearly cut off my finger cutting those welds with an angle grinder. This could be the case with yours or there could be many other options
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-16-2018, 11:23 AM   #4
cal0077
Re: 56 Apache
Thanks for the replies, I think its what you are talking about Dan. The angle strips. When I get home tonight I will take some pics of inside of bed. Here is a picture of when I picked it up and you can see all the gray primer marks where it was drilled
Old 06-16-2018, 08:44 PM   #5
duramax55
Re: 56 Apache
not a very good pic but from what i can see that is where the angel that runs on top of the floor of the box.
duramax55 is offline   Reply With Quote
Old 06-17-2018, 12:03 PM   #6
_Ogre
_Ogre's Avatar
Re: 56 Apache
not sure chevy used any oem angels in tf trucks, maybe later years
but yes that is the area that the bed angles were spot welded
typically the angles are plug welded back in
shop air compressor timer
Old 06-17-2018, 02:26 PM   #7
cal0077
Re: 56 Apache
Here is a pic of inside the bed. I think there is a L bracket missing. Do they sell these to be welded back on?
Old 06-17-2018, 05:43 PM   #8
dsraven
Re: 56 Apache
sheet metal shop could whip one up in minutes if you have a guage thickness and a dimension. cheap and ready while you wait prolly.
Old 06-17-2018, 09:02 PM   #9
cal0077
Re: 56 Apache
but does anyone sell them premade I wonder?
Old 06-17-2018, 09:36 PM   #10
Rods57
Rods57's Avatar
Re: 56 Apache
Yes LMC, Brothers and others sell them. I put one in and they are pretty easy. they do have the square holes for the correct bolts too. its called the angle strip in the catalog.
Rods57 is offline   Reply With Quote
Old 06-18-2018, 07:10 AM   #11
Kim57
Kim57's Avatar
Re: 56 Apache
Here's a link to the Brothers site.
Kim
https://www.brotherstrucks.com/Angle...products/1516/
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-18-2018, 12:27 PM   #12
cal0077
Re: 56 Apache
thanks everyone
Old 06-18-2018, 08:42 PM   #13
_Ogre
_Ogre's Avatar
Re: 56 Apache
if your not trying to build a stock truck, i used 1.25x1.25x.125 angle
Old 06-18-2018, 09:56 PM   #14
Dan in Pasadena
Re: 56 Apache
Don't forget to look at Mar-K's site.
Nearly EVERY aftermarket part supplier for these trucks carries them in both carbon steel to be painted and in polished stainless to simulate chrome.
Old 06-19-2018, 11:21 AM   #15
cal0077
Re: 56 Apache
Great images and help....I ordered them in steel from brothers since they will be painted
Thanks again
chris
