Old 05-30-2018, 09:19 PM   #1
T0ple55
Blazer body shim vs core support
Wondering which way would be the better way to go. I either need to shim my core support up or take body shims out to get my front fender and door alignment. Any input is appreciated.
72 GMC Suburban (dads)
69 SWB Chev (frame off father/son)
70 2wd Jimmy+69 4WD Blazer = PHASED
71 SWB stuffed in the barn
T0ple55 is offline   Reply With Quote
Old 05-31-2018, 12:47 PM   #2
SeventyOne
Re: Blazer body shim vs core support
Going to be really hard to diagnose problems like this but I know the B pilar alignment/shim is pretty critical.
First question though - do you have NEW body mounts in and is the top on?
SeventyOne is offline   Reply With Quote
Old 05-31-2018, 01:05 PM   #3
T0ple55
Body mounts are brand new. Ordered one of the full rubber sets from classic heartbeat I believe. I replaced the shims exactly as the were before. The top will not be going back on.
Old 05-31-2018, 01:09 PM   #4
SeventyOne
hows the door to b-pillar alignment?
If thats good then keep moving forward towards the front of the truck.
Old 05-31-2018, 01:23 PM   #5
T0ple55
B pillar alignment is good, was a little bit of a pain but got it in place
Old 05-31-2018, 01:57 PM   #6
hemi43
hemi43's Avatar
Tub/body shims get done first for correct door alignment. The last body mounts to be adjusted are the rad support ones. Do it out of sequence and you'll end up with a can of worms.
hemi43 is offline   Reply With Quote
Old 05-31-2018, 03:18 PM   #7
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Are there any write ups on this? I just put mine back where they were as well... But am just starting to put doors etc on... and not sure what the PO might have done...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 05-31-2018, 03:48 PM   #8
SeventyOne
It's written about in the factory assembly manual. Maybe someone can post a pic. Also I do recall seeing it in previous threads - try searching.
Old 05-31-2018, 07:56 PM   #9
T0ple55
OK sooo. I'm going to go ahead and shim the core support then. Next question are there specific shims for accomplishing this, as mine had none before. Can I use body shims in the core support locations? What about some suburban/truck rubber mounting pads?
Old 05-31-2018, 09:02 PM   #10
cleszkie
cleszkie's Avatar
Originally Posted by hemi43 View Post
tub/body shims get done first for correct door alignment. The last body mounts to be adjusted are the rad support ones. Do it out of sequence and you'll end up with a can of worms.
x2
cleszkie is offline   Reply With Quote
Old 06-06-2018, 03:19 PM   #11
1972 Banana
1972 Banana's Avatar
Would love to see the factory procedure as well, anyone want to share?
1972 Banana is offline   Reply With Quote
Old 06-07-2018, 08:34 PM   #12
hemi43
hemi43's Avatar
FWIW, it's been 3 years since the restoration, and I developed a small rattle in the driver's door latch area. I noticed the gap at the rear of the door was not parallel anymore and was wider at the top. I loosened the rear body mount on the driver's side as well as the one in front of it by the filler neck of the fuel tank. I added a 1/4" shim in both and tightened it back up. This was enough to get rid of the wide gap as well as the rattle by the latch.
Old 06-10-2018, 08:20 AM   #13
chevyguy_72
Vintage Evil
Is this the page you guys are referring to? Not much info here...
Current Rides:
Old 06-12-2018, 05:28 PM   #14
chevyguy_72
Vintage Evil
Anyone?
Current Rides:
Old 06-18-2018, 10:00 PM   #15
T0ple55
I dont believe it is, looking for the alignment of fenders to doors. whether to shim the core support or take the body shims out
Old 06-19-2018, 06:29 AM   #16
Woodsloafer
Subscribed
Woodsloafer is offline   Reply With Quote
Old 06-20-2018, 04:09 PM   #17
hemi43
hemi43's Avatar
That has already been answered for you ! The core support shims will align the fenders to the front of the doors. It's really not rocket science. Don't touch the body tub shims unless you have door to body issues. Not trying to be rude, but if you can't visualize what needs to be done, then maybe it's best that you take it to someone that knows what to do.
Old 06-20-2018, 04:22 PM   #18
T0ple55
Yeah we got that much, my response was to the image members were looking for related to @seventyone and @bananas comment about it being in the factory assembly process
Old 06-21-2018, 10:42 AM   #19
chevyguy_72
Vintage Evil
And i was looking for the manual pages because my tub has been removed from frame as well as had floor etc patches welded in by the PO... so trying to figure out if my door alignment issues are related to missing shims from when they pulled the body and left them out or due to the repair work... so if someone can point me to the correct page in that manual or the correct manual it would be appreciated.
Current Rides:
Old 06-21-2018, 12:19 PM   #20
SeventyOne
Let me dig out my book...
Old 06-21-2018, 12:45 PM   #21
chevyguy_72
Vintage Evil
Would appreciate that...
Current Rides:
Old 06-21-2018, 01:09 PM   #22
A1971Blazer
A1971Blazer's Avatar
This is from the factory assembly manual
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-21-2018, 01:10 PM   #23
SeventyOne
thats it.
Old 06-21-2018, 06:04 PM   #24
chevyguy_72
Vintage Evil
Attachment 1795132
Cool thanks
Current Rides:
