Old 06-19-2018, 03:59 AM   #1
Killer Bee
Killer Bee's Avatar
Re: Automatic Transmission Question
op referring to the torque converter dust cover? doubt that would do much for cooling..
adding a higher capacity trans cooler up front would make the biggest difference..
smaller gains could be made with deeper pan, aluminum finned pan, or tube cooled pan like derale..
good luck!
Killer Bee is online now   Reply With Quote
Old 06-19-2018, 08:14 AM   #2
BRL
BRL's Avatar
Originally Posted by Killer Bee View Post
op referring to the torque converter dust cover?...
That's the only one I could think of that he might be talking about.
BRL is offline   Reply With Quote
Old 06-19-2018, 11:07 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
This guy below me has a grate idea.I have a friend that is a plumber and a AC guy he drives around in a 1989 Chevy 3500 Big box van.He was having so many problems with his trans braking down.He found a old small window AC unit and Pulled out the Alum and copper coil that the Freon use to go throw this one was a rather Fat 3 core 10X12 he soldered 2 hose ends on put a electric fan on it and His trans never gave him a problem again
stsalvage is offline   Reply With Quote
Old 06-19-2018, 12:19 PM   #4
cleszkie
cleszkie's Avatar
I found the best way to cool my auto tranny was to swap in a manual tranny This also cooled down the engine temps by not taxing the radiator with hot tranny fluid. Probably not the solution for most people, but I tow a lot and needed to reduce heat and increase strength and reliability.
cleszkie is offline   Reply With Quote
