Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Trucks For Sale
Old 06-19-2018, 11:56 PM   #1
SoCoC10
SoCoC10's Avatar
1971 Chevrolet Cheyenne K20
1971 K20 Cheyenne 4X4 3/4 ton truck.
Well documented truck has all of its original sheetmetal and paint with ZERO RUST! That's right! ZERO RUST! Original rockers, cab corners, cab floors, windshield frame and drip rails have NO RUST! Truck comes with the original owner's manual and Protect-O-Plate.
Truck has all of it's jack tools, jack assembly and jacking instructions. Truck has its original Cheyenne woodgrain door panels, arm rests, chrome trimmed (Cheyenne only)headliner, it even has it's original carpet with carpet tag in tact! Dash pad was replaced but will come with the original dash pad with the dated tag still attached.
This is a real 3/4 ton Cheyenne K20 as documented on the Service Parts Identification(SPID)tag inside the glove box.
The Service Parts Identification tag(see pictures) reads
Model:KE20934(also on the firewall)
Which breaks down as
Chassis type: K = 4 Wheel drive
Engine type: E= 8 cylinder
GVW range: 2= 5200-7500 3/4 ton
Cowl to axle dimension: 09= 54-59"
Model type: 34 = Cab and fleetside pickup
The VIN# on the door jamb, matches the SPID and the frame.
The SPID tag also lists all the options the truck was built with from General Motors factory. Those factory installed options are:
Medium Blue and white exterior
Blue vinyl interior(Upgraded with a brand new Truck World made in USA blue and black Cheyenne Super houndstooth seat)
Camper wiring
Camper mirrors
Heavy Duty battery
Auxiliary battery(RARE)
Tinted glass
Locking front hubs
Power steering
Turbo Hydra-matic Automatic transmission
350ci V8 engine
Upper and lower bright body trim
Deluxe Gauges with Factory Tachometer
Custom Sport Truck(Cheyenne level trim)
Cheyenne also has dealer installed Air Conditioning!
The original numbers matching 350ci V8 runs great, starts right up, doesn't smoke and doesn't leak. Automatic transmission shifts well and doesn't leak. Bulletproof NP205 transfer case works like it should in two wheel drive, four wheel drive and four wheel drive low. Power steering and power disc brakes work like they should. Truck runs and drives great! Drives at 65-70MPH with no squeaks or rattles. Odometer reads 13,000 miles so most likely it's 113,000 miles but with a five digit odometer true miles are unknown.
Don't miss this opportunity to own a real factory built 1971 4X4 K20 Cheyenne.
$22,999 No trades
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 06-20-2018, 12:37 PM   #2
dell72
Re: 1971 Chevrolet Cheyenne K20
Where was the truck built? Do you have the OEM steering wheel?
dell72 is offline   Reply With Quote
Old 06-20-2018, 01:38 PM   #3
SoCoC10
SoCoC10's Avatar
Truck was built at the St Louis GM plant. The truck has a wood Sport style steering wheel. I'll happily keep it and put on the 12" black foam grip wheel, and give $200 off if you'd prefer it?
Old 06-20-2018, 01:42 PM   #4
Killer Bee
Killer Bee's Avatar
KE241S******
St. Louis
nice truck, GLWS!
Killer Bee is online now   Reply With Quote
Old 06-24-2018, 09:13 PM   #5
SoCoC10
SoCoC10's Avatar
Sold
