Old 05-06-2004, 06:03 PM   #1
shavedchevy
shavedchevy's Avatar
Unhappy uh oh
so i went out to my truck this morning, backed out of the parking stall, put in in drive and something went CLUNK!!! I could feel it in the floor so I'm thinking that it's the tranny. What could it be? (I'm not to mechanically inclined) It still drives fine but I'm sure that you can hear it from the outside.
Dennis
shavedchevy is offline   Reply With Quote
Old 05-06-2004, 06:40 PM   #2
C-10volvo
C-10volvo's Avatar
does it do this clunk just when shifting into gear? these trucks are prone to having some play in the read end. park your truck, put it in nuetral (e brake set) and crawl under there and see if you can move your driveshaft around at all. if you can, your problem is with the read end.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 05-06-2004, 07:00 PM   #3
Russell
Professional Grade
Russell's Avatar
Mine does that all the time. Esspecially in reverse. Sometimes it bangs hard enough to give me whiplash, lol
I know my rear end was put back together poorly, my grandfather broke it a couple years ago, and put a 4.10 gear in place of the broken 3.73 one.
It drives fine, but clunks something nasty when I put it into reverse.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-06-2004, 07:03 PM   #4
r0lf-
Hotwheels?
r0lf-'s Avatar
Yeah, mine does it into reverse pretty dang bad too. Wow. I never knew it was the rearend though... nice to know.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 05-06-2004, 11:46 PM   #5
Kybol
Kybol's Avatar
Mine did it pretty bad, then I swapped in a new rear end that was in better shape, and it pretty much went away.
-90 454ss http://www.imagestation.com/album/?id=4289115843
-04 TRX450R
-77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD
-82 c-10 SOLD
-02 CRF450 SOLD
Kybol is offline   Reply With Quote
Old 05-07-2004, 05:27 AM   #6
1986Silverado
What I drive
1986Silverado's Avatar
Check your transmission mount.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 05-07-2004, 08:21 AM   #7
gldevall
gldevall's Avatar
Mine stopped doing that after I changed to the Eaton posi and new gears.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 05-07-2004, 11:43 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
TH400s are known to engage pretty firm going into reverse. It could be a couple of other things that cause what you are experiencing though.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 05-07-2004, 12:25 PM   #9
shavedchevy
I know what you guys mean when it always goes clunk... our 81 farm truck did that alll the time to, but it wasn't as harsh as what I have now. I'll crawl under there this weekend and see what up.
Dennis
Old 05-07-2004, 12:57 PM   #10
Grim Reaper
Bad U-Joints, Loose spline in tranny, High gears, bad tranny mount and out of adjustment rear brakes can all cause a clunk.
Slip yoke trannys are famous for a clunk. GM even had a special blue grease that got rid of it for a couple thousand miles.
Brakes not being adjusted would cause a clunk when you come to a stop and then lift off the brake you would get a clunk and sometimes feel like therear just dropped. The suspension would bind up a little because of the brakes out of adjutment and the bag was it relaxing and tension suddently coming off the diff and drive shaft.
I would make sure you U-Joints are ok. Maybe check the brakes and pull the cover on the diff and they not worry about it unless you start to get crucnhy noises or a whine around 45mph.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 05-07-2004, 01:31 PM   #11
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yeah, for sure don't let it go and not find out what it is. A bad u-joint can send you pole vaulting. IMO, noises are warning signs. When you hear one you haven't heard before, it's a warning something bad is getting ready to happen. Heed the warning.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
