#151 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Sparky's 1978 Silverado Build "Addiction"
Nice work getting the pieces primed and painted!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#152 |
68 C 10
![]() Join Date: Aug 2010
What kind of paint did you use? I just read both of your projects from start to finish lol now I need a nap lol. Great work on both jayson is killing the paint on the other truck
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
#153 |
![]() Join Date: Feb 2008
![]() Summit DTM Epoxy, I believe, covered with.....1.5 quarts of Rustoleum Satin Black mixed 8:1:1 (hardener and reducer). Driver! Lol
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#154 |
Should I replace this upper control arm stud? The rest of the upper control arm bolts are good. Thanks Mike
#155 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#156 |
I'm 50/50 on it. My luck is that it wouldn't come out!!!!
#157 |
Mine came out fairly easy, kind of like a wheel stud, I just put a sacrificial nut on the end of the stud and pounded it out (and penetrating oil)......this is for the stud that is pressed in the cross member btw, is that what you're asking about?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) Last edited by moregrip; 06-06-2018 at 01:35 PM. |
#158 |
Yes, there are two studs on both sides that attach the upper control arm to the crossmember / frame. Should press in like a wheel stud.
#159 |
I'm just glad to be here!
I'd replace it. Looking at the threaded portion, it appears in the picture that it has been stretched, and the corrosion has reduced its diameter in the unthreaded portion.
Better to do it now while you have it apart!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#160 |
Great points! I’ve got four studs in the way! Thanks for the input. Mike
#161 |
Small update!
#162 |
Nice!
I see a two link and an airbag bracket too...
#163 |
................Observant!
#164 |
That's a nice wheel/tire combo. I think I'll be going with something similar, classic look FTW!
#165 |
Thanks Chief!!!
#166 |
So, got a lot done late this afternoon and this evening!!! I want to get the LS/Trans on this thing before the end of the week....lots of parts on the way!! Extensive kit front and back.
Pictures: 1. Drilling the holes for the upper air bag bracket....pain. At least the x-member wasn't on the frame and easy access! 2. Getting ready to install x-member. 3. X-Member attached and upper control arms mounted. 4. Got bored with the front and went to the rear end for a while. Test fitting panhard bar bracket. Will weld in place when I'm satisfied. I'm putting it in front of the rear end because I haven't decided if I'll put a rear tank in????? Or a narrow 6x15 spair tucked up tight, not sure that'll work??? 5. Panhard test fitting. The panhard bar will attached to the frame with a welded in bracket. 1 of 2 Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 Last edited by Dads79GMC; 06-20-2018 at 09:44 PM. |
#167 |
2 of 2
I have not set the pinion angle, so I won't weld-in the perches to the axle tube until that is done. Haven't decided if I'm gonna remove the original spring perches????? I probably will. YA! Pictures: 1. Up front done for the night. 2. Perches, or whatever they are called (engine stands??), are ready for install tomorrow. 3. And, a load of parts for the suspension ready for install as well. Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 Last edited by Dads79GMC; 06-20-2018 at 09:49 PM. |
#168 |
Looks excellent Mike! Nice work!
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
#169 |
Thanks Jayson
#170 |
Looking Good!
#171 |
#172 |
Bottom line up front: I love the Western Chassis drop spindles. When I had the tire mounted and balanced, I told them to put sticky weights inside rather than the normal ones on the edge. My last set of spindles would just take them off at the tie rod connector with an 8" rallys. Now I need to take them back and have the wheels rebalanced with the normal weights...blah! I also manually tested the front air system...will have to remove the bump-stops....blah again!
Pictures: 1. Thought I'd have room between the bump-stop and the bag, not when deflated! off come the bump-stops. 2. Lots of room between rim and tie rod connector 3. Ready for the LS tomorrow! 4. Front shot. 5. Installed an old caliper to get a feel for the spacing. I slammed the bags and there seemed to be plenty of room at the lower control arm for turning in both directions? We'll see when the LS is in?? Thanks Mike
#173 |
Spent the evening taking apart the front end to remove the bump stops on the lower control arms and installing the calipers and brake hoses. I will be installing a new bump stops that work better with the air bags.
Pictures: 1. Woke up and remembered that I had this tool!!! It's a time saver. 2. Installed brake caliper. 3. Wrapped up for the night. Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 Last edited by Dads79GMC; 06-22-2018 at 10:24 PM. Reason: Add pictures. |
#174 |
Lookin' good. I'm taking notes...
#175 |
Nice work Mike!
Ilkka 1984 Silverado 6,2d http://67-72chevytrucks.com/vboard/s...d.php?t=731803 BMW 325i 1989 http://67-72chevytrucks.com/vboard/s...d.php?t=797823 |
| Bookmarks |
