![]() Join Date: Jan 2003
1980 c10 250ci gear ratio
1980 C10 LWB, 250ci rear gear ratio in 12 bolt?
Not my truck, looking to get a better gear ratio for towing. No spid either
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
Re: 1980 c10 250ci gear ratio
2.73 most likely, based on my 78 and 82.
2.56-3.73 possible. 3.43 works decent for towing. Remeber with a 250 you're not going to run 70mph down the highway with a car hauler.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
I have a 1978 Big 10, It has a 350/th350 combo and has 3.08 gears. Was hoping it would have 3.42 or 3.73 gears behind that 250 parts truck.
My 250 got a 3.08.
Bonus to a 3.08 already in your truck is you already have the 3 series carrier. Just buy a set of gears to where you want it to be, cheaper than a whole rear end just to rob the gears from. |
The local mechanic wants 1200 to set up rear end with gears. The other axle is $100
3.42 was an option for a 80 250, if the rear GVWR is 5600 or 6000
MY '78 250 3ott truck has 3.73's
About the only option my truck had from factory in '78 was the 3.42 rear gear. It was a 250 inline 6 with the 3 on the column.
1978 Hawaiian Blue GMC 454/Tremec TKO 500 BUILD THREAD |
