MI-Rear Coil Springs:
Getting ready to lower the rear of my 69 by changing the rear coils springs. I was asked yesterday as to why not just start by cutting the old springs in half with a saws all first? It seems like once the truck was jacked up with some of the tension off that would be one way to do it if you didn't want the original springs anymore. Has anyone done this?
laying low
![]() Join Date: Mar 2001
Re: MI-Rear Coil Springs:
Once you remove the shocks just jack the frame up until the tension is off the springs. You will have to raise it far enough to put in the new springs anyway. No good reason to cut the old ones. You might want to go back to stock springs one day.
Cruzin
Yea, cutting is just work for nothing. You still have to remove the two bolts anyways, it's simple swap. I did mine laying in the back yard lol.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Moderator
![]() Join Date: May 2007
You can cut the front springs, not the rear.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
