I have a 1980 Chevy
Re: Interchangeable parts from a 1980 to a 1969 Chevy
Easily is a relative term but MOST parts will swap.
The Disc brakes will swap. You will probably want to swap the rear end also because it would have the same 5 lug rotor/hubs. Your 1969 has 6 lug rotors. Power steering should swap. Bench seat should swap. The A/C is NOT going to swap easily (if at all). note: I'm not an expert on square body trucks (ie 1980). So some of my info might be wrong. |
#4 | |
Thanks for the great info!! When you say P/S will does that mean the gearbox or just pump?? Posted via Mobile Device Last edited by Cgaines78; 06-23-2018 at 10:07 AM. |
![]() Join Date: Jun 2002
The gearbox and the pump should both swap easily.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Steering wheel, back glass maybe?, front xmember is a bolt in swap, seat if you change to your 69 brackets. Im sure there is more.
The 69 has a short water pump and brackets, so if you use the 80 pump for the PS it will require the short pump brackets. And it MIGHT require the short pump reservoir as well.
blood type; Retumbo
Brake booster swap. It "can" fit but you'll need a saw, welder, tape measure and a sharpie marker. Plus you need to learn how to cuss, swear and hold your tongue just right. I did it 14+ years ago and it's still going strong.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
So if I have a C20 72 2wd and the steering box leaks...what year of steering box would swap right in...any 73 to 80 3/4 ton?
plenty of threads here on the disc swaps.. .30+ yrs ago i swapped in the entire front xmember for the brakes so a little fuzzy in the details....re-used the early center link ,box and idler and had to come up with a mix of tie rod parts to adapt to the square body spindles....but for all i know all the square body stuff would have fit, the x member just didnt come with them....think i had to modify the lower shock mount on the arm so it lined up better... again check the threads cause there are other ways to do this without putting in the whole xmember....i was lucky as my 70 used the same length rear axles as the later ones, but i believe your 69 had shorter axles (provided it still actually has its original rear...a lot can happen in over 40 yrs....just measure between the backing plates.... if one truck is coil spring and the other leaf you'll have to weld on perches and shock mounts to swap rears
1970 short step c10 leaf spring 454 |
