![]() Join Date: Apr 2014
VDO gauge problems
I have changed out my stock gauges for a set of VDO classic gauges. Everything looks good. The problem is the Oil Pressure, Water Temp, and Fuel Level all read about half of normal. I have tested the gauges per VDO instructions, they are ok. I have tested the sending units they are good, they are all new. I have tested the ground and even ran a direct ground from the frame to the gauge cluster. I am at a loss as to what is the problem. Help?
Re: VDO gauge problems
My truck iis 67 SWB Stepside.
Fricking metric to standard conversion issues...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
