Old 05-31-2018, 11:47 AM   #576
chewychevy67
Re: 67 GMC super custom build
Not my 67 but I thought I'd share my latest acquisition. 2001 chevy 2500hd 8.1l and Allison transmission loaded. I drove this home 700 kilometers and I absolutely love it. Can't wait to tow with it!
chewychevy67 is offline   Reply With Quote
Old 06-09-2018, 09:08 PM   #577
chewychevy67
Test fit my wood bed today. Turned out great. Won't tighten it down till its all done.
Old 06-10-2018, 12:31 AM   #578
68bowtie
68bowtie's Avatar
Looks amazing!
Old 06-22-2018, 05:19 PM   #579
chewychevy67
Had some work done to my firewall. This time it won't be full of body filler. I had the the area around the dimmer switch recesses further down so the auto dimming headlight harness can sit low under the rug and I had an area recessed for the radio foot controller and its harness so it looks like it was there stock. I also had a harness connector added above the speedometer hole to make clean work of Connecting the added accessories I am using. Last one is my thermometer with the gm decal on it.
Old 06-26-2018, 07:56 PM   #580
chewychevy67
Got these 2 pieces today from a 57 cadillac. Going to see how I can get the fog light circles into the truck bumper.
Old 06-26-2018, 08:33 PM   #581
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
You aren't going to run 4 Fog Lites are you?
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 06-26-2018, 09:37 PM   #582
chewychevy67
No. Only one on each side. 57 cadillac had 2 fog lights and 2 signal lights. I am only using the fog.
Old 08-12-2018, 11:03 AM   #583
chewychevy67
I had these parts removed from a 1967 Buick 400 transmission and I am going to add the. To my th400. These are the pieces required to allow your th400 to change the stall speed of your converter with 12 volts. Gm used this in 65 to 67 Buick old and cadillac 400 transmissions and can be adapted to chevy 400s with 8 bolt cases. It's pretty neat. I got my gear vendor unit as well so I can finish the transmission now.
Old 08-12-2018, 04:18 PM   #584
chewychevy67
And the gear vendors
Old 08-21-2018, 05:42 PM   #585
chewychevy67
I got member tbone1964 to calibrate my 4k cable driven tach into a 5k tach and added a tach drive distributer to my engine. Wow did tbone1964 do an amazing job. SUPER HAPPY. With the ti ignition from the 60s I wanted my tach to be somewhat accurate and I don't believe that ti ever used an electric tach on Camaros it came in.
Old 08-21-2018, 10:17 PM   #586
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
That looks so cool!!!! Old school period correct.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Mechanical Diesel Tach, Vac, Kilometre Speedometer, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Steering Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt, Chewychevy67.
Canuckvetter is offline   Reply With Quote
Old 08-22-2018, 12:01 AM   #587
68bowtie
68bowtie's Avatar
I got member tbone to calibrate my 4k cable driven tach into a 5k tach and added a tach drive distributer to my engine. Wow did tbone do an amazing job. SUPER HAPPY. With the ti ignition from the 60s I wanted my tach to be somewhat accurate and I don't believe that ti ever used an electric tach on Camaros it came in.
sweet!!
Old 08-30-2018, 11:52 PM   #588
chewychevy67
I have been playing around with swaping my Vacuum gauge for a transmission oil temperature gauge. I got this oil temp gauge from a 1980 corvette and I took an extra gauge face I had and painted how I would like it to look. With the switch pitch converter I've been told the transmission will make more heat. Nothing to be worried about but I would rather this gauge than a vacuum gauge I think. Would be more beneficial if I ever tow. I would put the words "TRANS" on the lens.
Old 09-01-2018, 11:36 PM   #589
chewychevy67
Well I decided I wanted to keep the vacuum gauge and I wanted a transmission temp gauge so I am getting creative. I know on the 73 87 trucks you can get a tack and fuel gauge in the large right gauge so I thought I can do that too. I also didn't want to see the full needle so it would look proper like the smaller lower needles and I didn't want to mess around my printed circuit. So after lots of thought I came up with this. I am going to have my fuel gauge face reprinted so it all looks smooth but I'm pretty sure I can make this look good. Plus I don't have to mess with my brake/temp emergency lights either. I'm sure. I'll keep playing with it on my spare gauge cluster till I decide if I will do it to my main one.
Old 09-11-2018, 07:29 AM   #590
mcbassin
Still Learning
mcbassin's Avatar
Nice work as always Chewy!
Old 09-11-2018, 08:20 AM   #591
YoungPup1977
Are the variable pitch parts for the TH400 available for sale ?
YoungPup1977 is offline   Reply With Quote
Old 09-12-2018, 12:10 AM   #592
chewychevy67
No I want to install them in my transmission. I do have another set of wiring which includes the carb switch and dash pot but that's all I have available.
Old 09-24-2018, 09:11 PM   #593
chewychevy67
Getting my gmc script valve covers started! The ones they should have made from the factory
Old 09-25-2018, 01:16 AM   #594
NewType72
NewType72's Avatar
Those covers are so rad! Love it
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-25-2018, 12:00 PM   #595
Graham57a
Graham57a's Avatar
What did you get the GMC script from for those valve covers? Looks killer!
Graham57a is offline   Reply With Quote
Old 09-25-2018, 02:39 PM   #596
chewychevy67
They are from gmc v6 valve covers
Old 09-25-2018, 03:42 PM   #597
Graham57a
Graham57a's Avatar
So you had to sacrifice a pair of v6 valve covers?
Old 09-25-2018, 04:44 PM   #598
chewychevy67
I did. They sat in my shed for 2 years. I was going to sell them instead but I really thought this would be the finishing touch on my engine. So I cut them out. At least it worked out.
Old 09-26-2018, 03:30 PM   #599
68Gold/white
Would like to see and hear details of your welding to the valve covers, Thanks!
68Gold/white is offline   Reply With Quote
Old 09-26-2018, 04:22 PM   #600
chewychevy67
I never welded them. I had a shop do it. I don't have a tig welder or the skills for something this delicate. I'll post pictures when I get them back.
