Tilt Steering Column Help Needed!
I am not sure what tilt steering column is on my truck but it apparently is not originally from a 72 truck as most of the replacement parts I have ordered do not fit.
The steering rod end is splined and it has this coupling unit and a rag joint at the PS pump. I bought an aftermarket tilt column that has a 3/4 in DD on the end, is there a way to make this setup work? Do I need a DD to splined adapter? Do I need to keep the coupling unit since I have a rag joint? Any advice appreciated! |
![]() Join Date: Mar 2000
Re: Tilt Steering Column Help Needed!
The first one looks like a stock column to me. The second one is the same type of shaft as later columns use. I have a stock type column around here that uses that same D end on it. Came from a later RV I believe. I found an intermediate shaft and coupling at a wrecker that fit it.
Saskatoon, Saskatchewan Canada |
![]() Join Date: May 2010
Yours looks like an original truck tilt to me also. What parts have you ordered that don't fit?
That original column is worth some coin too!
I've ordered 2 turn signal canceling cams that did not work and a shift lever that did not fit. Is the coupling unit assembly after the spline needed?
laying low
![]() Join Date: Mar 2001
I'm curious why you would want to replace a factory tilt column. There is only one shift lever for a 71-72 tilt column. It is different than for a non tilt column.
https://www.classicparts.com/Dash-Pa...ducts/268/12/0 And two horn contact rings for tilts. https://www.classicparts.com/Dash-Pa...oducts/268/6/0
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 06-24-2018 at 06:00 PM. |
![]() Join Date: Feb 2004
Dude, unless you bought one of the big 3 columns, Ididit, FR, BS....you need to abandon your idea to swap. As mentioned that oe colum is worth coin, and much better made than the cheap overseas crap running around. There is plenty of write ups of those coming apart. And being loose. The plastic ball they use sux and will fail prematurely.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Its a Truck Thing......
I would pass on any Flaming River columns as I have installed one and a buddy has one and they are not worth the metal spent to make them. Very sloppy......
I have a 72 tilt on the ground from my motor home that I can take a pic to show you what it should look like if you want. Also have a Van Tilt here. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
![]() Join Date: Jul 2016
Your factory tilt column has a non tilt turn signal switch installed, order the cancel cam for non tilt.
Like someone said previously, order a shift handle for a tilt column. |
That makes sense. The Red 4 Way knob is only on the non tilt. It should be the black cone or the later black round cylinder with the sleeve.
#11 | |
Always on the hunt...
![]() Join Date: Sep 2006
![]() Horn contact/cancel cam thread link: http://67-72chevytrucks.com/vboard/s...d.php?t=515103 |
I was going to mention the spring and horn contact but you can see them in them installed in the first picture. Looks like he is covered on that.
#13 | |
Here are some pics of the shift lever that specifically said was for a tilt column, but it does not fit. Looking at it again it looks like with some grinding and filing, it should fit but I should not have to modify a part that is supposed to fit. I read the articles about the chinese columns and the one I bought is made in china but it is aluminum and looks to be well made. I called the vendor that I bought it from and they sell an adjustable shaft/u-joints/splined adapter for the steering box. No rag joint but the rep said he has ran this setup before without a problem. I have to admit I am on the fence but I do want turn signals that work, a shiny non-rusty gear selector and a shiny chrome aluminum column would look nice!
#15 |
There are nothing but terrible reports about those Chinese columns, they wear out as soon as put in service or sooner. Just put it on the shelf and don't throw any more money at it.
As for the shifter...there is a spring inside where it is inserted, towards the dash side, are you jamming the shifter up against the spring and it wont insert fully or it doesn't fit the hole? The shifters in the picture appear to be interchangeable. I cant make out what the item in the first picture is. |
#16 |
I, also, had to do some "grinding and filing" to get the lever I bought to fit into place. It didn't take much and is not visible. It was almost as if they didn't allow for the thickness of the chrome plating. Once done, it works fine and looks great. To me, it was a minor inconvenience, but you are right, modification shouldn't be required.
